My car is not working
08.05.2020 16:25 # 1
melih26
Friends, please help me, I didn't know what I would do. I had a peugeot 207 vehicle. I turned the ignition maybe 5-6 times, then it worked like it worked and worked but my car stopped constantly, I filled the gasoline, I filled the tank but in 2 days, although I used my car very little, I ended up on my petrol without making a 1-kilometer drive. It doesn't work alone when my car is standing outside, it works so hard, it turns out very hard to turn the ignition 3-4 times and press the gas. When I use it, it was enough to turn the ignition 1 time, it was working instantly, but it is not like that anymore. What is the problem? Reviews
08.05.2020 16:25 # 2
serommm
Replace your battery. That battery is already discharged.
In theory, if the car will sleep for more than 1 month, you need to remove the car battery terminals. 30:36
08.05.2020 16:25 # 3
djchaos
After starting your long-running vehicle, you have to put it into service as soon as possible, you should do all the periodic maintenance such as oil, air filter etc., the battery should be changed, the polar heads should be cleaned, the tires should be checked, the water antifreeze spark plugs should be used with peace of mind after a good maintenance.
08.05.2020 16:25 # 4
06OzGuR06
Have it maintained, connect it to the computer. Replace the battery and have the fuel system checked. I think there is nothing serious.
08.05.2020 16:25 # 5
Ucyuzalti
Be careful that your gas runs out The gas hoses may have exploded when you don't see gasoline for 15 months, and it may have leaked when you put gasoline, it dried up when you say it bursts, it has opened when you put the gasoline on it.
