my car is not working
08.05.2020 16:32 # 1
sosyete_60
friends peugeot 206 xt & nbsp; 1.6 & nbsp; 16v & nbsp; I did not remove the car because of the weather was cold and I did not start the car for 3 days.
08.05.2020 16:32 # 2
yavuz25
can you start?
08.05.2020 16:32 # 3
estair
Did the car have anti-freeze and the car would not start if the petrol could be finished or if the crank reader did not read it manually
08.05.2020 16:32 # 4
yavuz25
[QUOTE = estair] did you have antifreeze on the vehicle, or if the gasoline is over, if you don't read the crank reader by hand, if you don't read the car, the car won't start [/ QUOTE] Since
is working at first, I don't guess that there are problemless drivers in our forum. "Smile"
08.05.2020 16:32 # 5
sosyete_60
I started getting starter, I turned on the headlights first, I was going to move, but it was silent and it didn't work yet.
08.05.2020 16:32 # 6
djchaos
car antifreeze is very important, I spoke to a friend this morning, 106 gti, I don't use antifreeze, no matter how you get used to the car, do not miss it.
08.05.2020 16:32 # 7
sosyete_60
how does this crank reader
08.05.2020 16:32 # 8
yavuz25
[QUOTE = djchaos] car antifreeze is very important, I talked to a friend this morning, 106 gti, I don't use antifreeze, how do you get used to the car, how do you get used to it? / QUOTE]
the man who didn't put the antifreeze in the car, I wouldn't call it a driver. .gif "border =" 0 "alt =" Cry "title =" Cry "/>
08.05.2020 16:32 # 9
yavuz25
[QUOTE = sosyete_60] How does this crank reader
since the vehicle is working first, it won't be a problem. Have you ever tried to run it.
08.05.2020 16:32 # 10
sosyete_60
leave friends how to do antifreeze how this car will work
08.05.2020 16:32 # 11
sosyete_60
no, I tried 30 minutes ago it didn't work again
08.05.2020 16:32 # 12
estair
08.05.2020 16:32 # 13
yavuz25
[QUOTE = sosyete_60] leave friends how to do antifreeze how to work this car [/ QUOTE]
let's leave my brother in the antifreeze if you answered the question. ? "Wink"
08.05.2020 16:32 # 14
estair
dude take your akun to the press wait 10 minutes, reset it, let your brain try it again, make sure it's fuel
08.05.2020 16:32 # 15
yavuz25
this distance varya man finishes it is very difficult to guess something from afar. "Dead"
08.05.2020 16:32 # 16
sosyete_60
light is on, but I have gasoline, I am gasoline, the gas pump's sound came from the pole of the battery.
08.05.2020 16:32 # 17
djchaos
check the battery if it gets started, open the bonnet of the vehicle, don't have any cables that do freeze? is the pole head clean? You already know the fuel - you are talking about 14, the cables to the brain that go to the engine may have made freezing.
08.05.2020 16:32 # 18
estair
Dad, you can go for 20 lira.
08.05.2020 16:32 # 19
djchaos
take a good look at where the sensors are the sensors
08.05.2020 16:32 # 20
yavuz25
[QUOTE = djchaos] check the battery if the starter is picking up the car's bonnet, don't there any cables that freeze? is the pole head clean? You already know the fuel - you are talking about 14, the cables that go to the brain that go to the engine may have made freezing. . "Smile"
Page : / 2
