my car is not working
08.05.2020 18:32 # 1
alikrcoglu
selamunaleyküm friends 2000 model 206 1.4 xr prences vehicle did not start at the first start in the morning as if the starter motor will turn, but when I turn the key like there is something holding it, a single thim sound comes clogged problem over time, the engine went on until 1 hour stopped, so the second starter takes after the car started, so stopped it run, no problem, I took my car to the engine master, the engine oil gasoline filter changed, the problem still continued, I took it to the auto electrician, I recharged the battery again, the problem continued at the end, the starter dynamos took it to the coiler at the end of the engine, they dismantled their coal, they changed the wheel as worn, but the problem still continues. I am waiting for your help, I almost sell my car for 1 month, just for this problem, I am going to go to and from the industry.
08.05.2020 18:32 # 2
alikrcoglu
friends don't have any comments Dead
08.05.2020 18:32 # 3
Serkan
It looks like a battery or starter motor, but with a well-maintained, solid battery, the battery may not be charging.
08.05.2020 18:32 # 4
enes_468
You have 60% battery problem, the battery is not charging. with a different battery, you will see a thousand days difference. A 40% electrical component might be doing it personally. enes_468 2014-05-11 23:49:06
08.05.2020 18:32 # 5
kuscu38
If you are looking at the charging dynamo, look for another problem in the starter engine. With experience it is fixed. If the starter's coal is depleted or oil has gotten into it, it dissipates the current coming from the battery, causing the vehicle not to start, as if the battery seems dead. sometimes it makes a single throttle, and sometimes you get it after a little :) starter engine .. kuscu38 2014-05-12 13:36:49
08.05.2020 18:32 # 6
alikrcoglu
thank you guys for your answers yesterday evening, 10 times yesterday I tried to try and run the car today i brought the master, it worked like a click in the hands of the master, not to get mad, i am very curious, i am wondering what the problem is when i reach the conclusion, the friends I will write are very strange when i work in bikez it is unusual to work without giving problems ConfusedConfusedConfusedConfusedConfusedConfusedConfusedConfusedConfusedConfusedConfusedConfusedConfusedConfusedConfused
08.05.2020 18:32 # 7
kuscu38
it is always like that. You will suffocate from cough, you will go to the doctor, maşallah you have :)
08.05.2020 18:32 # 8
sabri_23
I also had the same battery changed, it was the evening, the same charge dynamo burned, we paid 400 TL, no problem, but if it is not like a charger, it can look dirty in the throat.
08.05.2020 18:32 # 9
alikrcoglu
friends, my car was not working in the morning because the water was getting to the engine, the water on the pistons said the masters said it might have burned the gas, there is a cost of 400 TL. no motorcyclist could find a auto electrician, so we don't understand much, he did a lot
08.05.2020 18:32 # 10
ahmed206
It's a pity that they opened a lot of expenses to you.
08.05.2020 18:32 # 11
emre_akdag
Get well with that, at least the problem has been found :)
08.05.2020 18:32 # 12
kuscu38
get well soon with him, hod ..
08.05.2020 18:32 # 13
SDYMZ
[QUOTE = alikrcoglu] friends said my car was not working in the morning because it took water to the engine, water was coming over the pistons said the masters could have burned the gasket, there is a cost of 400 TL tomorrow. worked for more than 1 month, no motorcyclists could find auto electricians, so we don't understand much, it worked hard [/ QUOTE]
So does your vehicle reduce water? I think get a diesel hose checked
08.05.2020 18:32 # 14
alikrcoglu
water was diminishing, put the water in the radiator water tank was finished in one day today the auto mechanic came out of the car cylinder head gasket two pieces
08.05.2020 18:32 # 15
ahmed206
Come on, my teacher, I think you have survived cheap again, burning the gasket could have had more serious consequences ...
08.05.2020 18:32 # 16
alikrcoglu
Thank you bro, have a nice day with us all.
