my car is not going help
08.05.2020 17:01 # 1
muro_60
Hello, I just joined your friends. my car peugeot 307 xt premium 1.6 16v 2003 model has been for 3 months or so my problem is that the car is not over 170 on the gas. very low at low gears, but after going over 100, they are holding the car in the sanctuary. I care about me, friends, I had my ford escort, I was 220i very comfortable. I would appreciate it if you help, regards, by the way, as I press the gas, snoring comes, there is an air filter like "Cry"
08.05.2020 17:01 # 2
First you need to introduce yourself. A link to my signature should be reached.
It should be easily accessible at a speed of 170 cid. How many kilometers of your vehicle? How is the maintenance status? When was the last time the air filter was replaced?
I recommend you to do a test. Once your car has run out of gasoline, buy 98 octane gasoline and try it. We can make the necessary discussion here by looking for any serious improvements.
koliva 2012-09-03 12:37:00
08.05.2020 17:01 # 3
sukur
I will look from a different perspective. If your vehicle has steel rims and these wheels are inexpensive fastening rims, it will tire both the layout and the engine of the vehicle over time. Many of the people I know who use more than the rim weight should have a problem not exceeding 170. As well as 170 i ...
(NOTE: my examples are for 206. I don't know the reactions of other vehicles)
08.05.2020 17:01 # 4
muro_60
I got my vehicle in 126000 at 1 week gasoline, I wonder if it is the problem, but it doesn't go the same. I'm stepping on the gas, snoring, don't eat, thank you for your interest & nbsp;
08.05.2020 17:01 # 5
muro_60
The original has its own steel pot, 15 cant effect on harelde.
08.05.2020 17:01 # 6
[QUOTE = muro_60] original has its own steel health, no 15 cant effects on harelde.
How is the maintenance? When was the air filter last replaced?
08.05.2020 17:01 # 7
muro_60
not at the authorized service, but when I bought the oil oil filter air filter spark plugs just changed, we put 5 30 in the oil
08.05.2020 17:01 # 8
[QUOTE = muro_60] is not at the authorized service, but when I bought it, I put the oil oil filter air spark plug in the new oil 5 30 [/ QUOTE]
If you do not use the original air filter + oil filter in your vehicle, it may be very painful. Definitely use original parts of this type. You don't have to appreciate it at the authorized service, but the parts will be original.
Recommended oil 5W-40 to your vehicle. The number 30 oil may sound fine. I am using SW of the same model of the same vehicle and I use Mobil 1 0W-40 New Life as oil. I think you should have a small service for your car soon.
koliva 2012-09-03 13:01:50
08.05.2020 17:01 # 9
muro_60
They don't know anything about slapping service, they just sell the vehicle. And they said to me that the catalyst could be clogged, so how can I tell if it is clogged
08.05.2020 17:01 # 10
mev347
it does not exceed 110u in my vehicle. drowning at high speed on slopes 70e falls. air filters oil filters fuel filter and oil changed. last year the pressure had changed to the pad, though the pressure could not exceed 110 even the day the pad changed. & nbsp;
08.05.2020 17:01 # 11
[QUOTE = muro_60] They don't know anything about slap service, they only sell the vehicle. And they said to me that the catalyst could be clogged, so how can I tell if it is clogged
The catalytic converter may be one of the reasons. You can find out if it is blocked by connecting your vehicle to the computer, but when it is connected to the computer, it will not appear as obstructed or not. I shared how it was done sometime in the forum.
It is very difficult to find a master who understands the vehicle well in many places. This is the reason for this forum. Thanks to each other, we learn something and help others with our experience. We become the master of our vehicle. This does not mean that we will repair every fault ourselves. We must first know what is what, how to fix it, and then we must solve the problem with the master. This is the logic I have been applying since the beginning. Reviews
08.05.2020 17:01 # 12
blinddark
I had the same problem with you a few months ago, my current car is 2003 307 1.4 hdi xr 70 horsepower my previous car was 1998 opel vectra 2.0 16v 166 horsepower, of course there is an inexplicable power difference in the middle. speed was 240 km and still going to go. Of course, some things got confused when I got 307 from the opel, even though my sister did not understand from the car. I made a speed on 28 June, I bought my car for a short time, I made 170 for one, I came to 160 la on the Anatolian highway last time & nbsp; I am sure it would speed up even better, but I never stepped on my car :) I do not give confidence as much as opel to print it.
08.05.2020 17:01 # 13
muro_60
Yes, you are telling the truth, if it wasn't in this form, we went down and everyone changed something.
08.05.2020 17:01 # 14
muro_60
the vehicle I went to was 95 hp, which is a better performance with 110 hp carpet. 170 even though it comes out so hard.
08.05.2020 17:01 # 15
fexzi
Is the tool automatic?
08.05.2020 17:01 # 16
volkan_uysal
110 BG can not be 170 borders, 130 ideal for safety reasons (on highway)
08.05.2020 17:01 # 17
muro_60
tool manual & nbsp;
08.05.2020 17:01 # 18
muro_60
no one will help ...
08.05.2020 17:01 # 19
reserpin
Unfortunately, your car is dead, 1500 pounds of turbocharger stuck in the turbo.
08.05.2020 17:01 # 20
muro_60
"Smile" & nbsp; vehicle gasoline brother & nbsp; even with tube :))
Page : / 2
