My car is hushing at 3000 rpm please help
08.05.2020 15:09 # 1
Cetinler
I own the 2005 model 206 van, when I came to work this morning, the engine malfunction lamp came on and after 3000 cycles, the car started not to gas and haze !!!!
I would be glad if friends who had this problem help before, what is the problem ??????
08.05.2020 15:09 # 2
I think the vehicle is diesel. There is a problem, the motor protects itself. I have read this kind of article before. I transfer from there ...
08.05.2020 15:09 # 3
dukenukem82
I think pull the vehicle to a workshop.
08.05.2020 15:09 # 4
Cetinler
yes my car is 1.4 diesel
08.05.2020 15:09 # 5
This is called limp mode, which is protection mode. The vehicle is protecting itself to prevent further damage. An error message should appear on the screen. What error does it give?
08.05.2020 15:09 # 6
Cetinler
it does not show any error messages, only the engine fault light is on.
08.05.2020 15:09 # 7
[QUOTE = L2940]
You have to connect your vehicle to the computer and scan the error.
08.05.2020 15:09 # 8
In antipollution fault warning, a breaker enters at 3000 rpm, to protect the engine. service is a must.
08.05.2020 15:09 # 9
fahri_y81
i have read this elsewhere (i might be wrong) egr valve may have failed. A malfunction with the same complaints.
08.05.2020 15:09 # 10
ask307
the same thing happened to me, I tell you the fault, the malfunction lamp turned on, then it did not exceed 3000 cycles, the car problem injectors or the diesel pump came out of both of them.
08.05.2020 15:09 # 11
Guys, please don't mislead. The vehicle can put itself in protection mode even from the slightest malfunction. There may be a lot of reasons for this. Malfunction may be large. You can only learn this by connecting it to the computer. Connecting to a single cause is currently impossible.
08.05.2020 15:09 # 12
Cetinler
Thank you to all the friends who are trying to help interested. There was a familiar master called him yesterday came and took the car from my workplace, brought it in the evening, said the problem was the gas grabber contamination (I don't know what the gas grabber was), he removed it, cleaned it, replaced it, erased the error message on the computer, had attacked more recoded its values for, indeed the car is more agile than before (I hope that after this coding, fuel consumption does not increase because it seems to me that it counts at idle)
When it comes to the expense, we will see you tomorrow.
08.05.2020 15:09 # 13
[QUOTE = L2940]
Get well soon.
