My car is flying in 2nd gear :)
08.05.2020 15:25 # 1
frenzy
Hello friends. I have a 2004 model 1.6 envy lpg Pug 307. I don't know exactly how my car's current acceleration should be because I haven't used 307 before, but there is obvious cumbersome. But the main thing I was interested in was that my car slowed down in a hump and shifted the gear to the 2nd place, and when I put on the gas, my car accelerates suddenly. Sırıtma Firstly, which situation should the car have; Is it the 2nd gear or the other normal course? Second, is this a problem, why does this occur in other gears?
Note: This is not always the case that I am bashing and is not in the whole cycle range. Sometimes it turns back to its original state at 4k speed or before or after. So I'm getting a short boost.
08.05.2020 15:25 # 2
tigerland
for the first time my hearth is like this :) always goes to the 2nd person 3 does not wear any
08.05.2020 15:25 # 3
frenzy
Then you go with a maximum of 70-80 at 5-6k cycles.
08.05.2020 15:25 # 4
He's done the joke anyway, otherwise you're not going to be in constant gear.
08.05.2020 15:25 # 5
frenzy
[QUOTE = badires] He has done the joke already, or you will not go in fixed gear. [/ QUOTE]
I got a joke Sırıtma
08.05.2020 15:25 # 6
You caught the joke, but if you go, you will grab it in the gasoline Sırıtma
08.05.2020 15:25 # 7
trigger
Dude, when you shift into 3rd gear, your torque is working up from low levels, but you will be 2 thousand if you are in gear while going through the hump. trying to increase the torque from 70 to 100 percent. From 3 to 50 to 100 ...
08.05.2020 15:25 # 8
frenzy
[QUOTE = trigger] dude, when you shift into 3rd gear, your torque is working up from low levels, but when you go through the bump you are in 2 thousand. trying to increase the torque from 70 to 100 percent. 3 to 50 to 100 ... [/ QUOTE]
It is not exactly so. I slow down thoroughly for the hump high groove. After throwing 2 and going a little bit, after one or two very small kicks, the car takes its head and goes away.
frenzy 2011-05-12 21:22:12
08.05.2020 15:25 # 9
trigger
Acceleration in 2nd gear is easier than in 3rd gear, but more expert friends may give more important information.
08.05.2020 15:25 # 10
GokhaN
1.4 1.6 is a normal thing because all the cars are already 2 to 3 gears in every car, with low speed and easy acceleration. I have a chip application in my own vehicle, for example 1.4 hdi, but it raises heads in gears 2 and 3.
