my car is discharging the battery
08.05.2020 16:45 # 1
sosyete_60
friends when the car does not work for 2 days, the battery is discharging I just bought the battery.
08.05.2020 16:45 # 2
turbo27
What is the vehicle? discharges the battery if there is an alarm, or there is a leg, show good to the electrician.
08.05.2020 16:45 # 3
sosyete_60
we did not find the car 206 xt 2001
08.05.2020 16:45 # 4
Alicilik
Pay close attention to the electronic additions made later. This kind of problems can happen when you go out of the fabrication.
In addition to this, the cable and electrical parts that are constantly moving and subject to impacts can wear out over time and touch the chassis.
If there is a luggage lamp, this may open the battery when the key is broken and can discharge the battery. Reviews
08.05.2020 16:45 # 5
feline
get past first
are there any installations ??????
yahu, if we open the following topics, we will not be able to open a detailed topic. If you haven't worked for 2 days, you said "How do we comment? How can we find a solution?" is there an alarm? was added later in the electrical installation "Angry"
is not even the model of your car is certain is it 206? 306,307.308 etc etc it goes, you wrote it in the signature part, you mentioned it when you open the subject edited> feline 2012-05-09 23:51:13
08.05.2020 16:45 # 6
@ socyete_60 introduce yourself .. browse the link I have given ..
08.05.2020 16:45 # 7
cerci07
had come to my side 1 month akude we did not start the car for a week, it was completely drained again After fully charging the battery, there is no problem.
08.05.2020 16:45 # 8
sosyete_60
feline you are right when the subject is open, ebey bi was missing my car 2001 model 206 xt 1.6 16v vehicle stopped working for 2 days if it does not work, it is discharging the battery, I changed the old battery just because they did not keep jarz, the battery was finished but now I bought a new battery and again the same problem was in the top of the car had a dvd cd player. We ripped off, we put on their original CD player and the situation is the same again, the battery is empty again.
08.05.2020 16:45 # 9
feline
It is very interesting, I advise you to take down the complete battery.
There is definitely a leak, there is no problem with the battery since it has just replaced the battery. check the options one by one
even lock the doors, look inside from there, it will come out of the little barrier as it empties in 2 days
feline 2012-05-10 00: 29:32
08.05.2020 16:45 # 10
sosyete_60
How do you know when there is a breakdown in the insurance table? Well, if I ask why I need to change my insurance, they couldn't find a wedding but they got money because something changed.
08.05.2020 16:45 # 11
Alicilik
Oxidation of the cables - wear over time due to movement, etc., as I said, can cause leaks. Your problem is solved with a good electrician.
Have you looked at the alternator, maybe it is not charging the vehicle
08.05.2020 16:45 # 12
sosyete_60
yes they looked they said it was very good to make jarz when they worked they measured it
08.05.2020 16:45 # 13
webbee
look at the door buttons, it is doing much more than there is in the window
