My car is blowing smoke
08.05.2020 20:29 # 1
Orcun.Dmr
First of all, greet everyone. 2005 model 307 1.4 hdi car started to smoke black smoke. When I bought it was 50 thousand km and now it is 225 thousand km. The vehicle has been in my personality for 7 years and so far I have been doing its services 2 thousand km in advance, and I have been getting the quality place in diesel. My friend who came from behind showed me his video if he wasn't smoking before, but when I was loading recently, he was smoking black smoke. Do you think it is possible to be from egr? or for what reason does it smoke?
orçun.dm is 2018-01-26 02:25:58
08.05.2020 20:29 # 2
hzr206
Burning fat can cause oil reduction, injector failure, turbo failure, egr and catalyst problem.
08.05.2020 20:29 # 3
Orcun.Dmr
[QUOTE = hzr206] burning fat that can cause oil reduction, injector failure, turbo failure, egr and catalyst problem. [/ QUOTE]
No fat burning and water loss problem. When I bought the injectors, I replaced them with the originals and had the catalyst canceled. If there is a problem in the turbocharger, the vehicle will not lift and stick to the seat as soon as it is pressed to the gas. But I don't know if my egr stuff is. It also throws smoke at high speeds, but I don't see the smoke behind me while driving, it doesn't smoke much. Smile
08.05.2020 20:29 # 4
egr probably
08.05.2020 20:29 # 5
GokhaN
[QUOTE = sonerkyl] egr possibly [/ QUOTE]
+1
08.05.2020 20:29 # 6
Orcun.Dmr
If it is egr, I clean it but i don't know where egr is in the engine LOL If I cancel, would I smoke more and increase performance? Can anyone who does not know please comment? at least it's an idea SmileSmile
08.05.2020 20:29 # 7
https://forum.peugeotturkey.com/forum_posts.asp?tıd=18476
08.05.2020 20:29 # 8
Popomundo
It is from Egr, walla I canceled the hose of the egr and plugged the bolt at the first gas throws smoke in the first gas, the car relaxes when it is canceled from the egr Smile
08.05.2020 20:29 # 9
Orcun.Dmr
[QUOTE = sonerkyl] https://forum.peugeotturkey.com/forum_posts.asp?TID=18476 [/ QUOTE]
I don't have anything to cancel egr right now Smile
08.05.2020 20:29 # 10
Orcun.Dmr
[QUOTE = Popomundo] It is from Egr, walla I canceled the hose of egr and plugged the bolt at the first gas throws smoke at the first time, the car relaxes when canceled from egr Smile [/ QUOTE]
Bro I don't want to cancel because I don't want the car to smoke Smile But if I investigate a little more, I will find and clean the egr, and I will also clean the intake manifold. While it was 210 km in the past, it is staying in the 190s now. LOL
08.05.2020 20:29 # 11
ruhela
When I first bought the car, I had such a problem, I cleaned the injectors, it sounded like it was burning, it improved. It was both a black smoke and a fuel issue.
Have a look at the injectors after Egr.
08.05.2020 20:29 # 12
Orcun.Dmr
[QUOTE = ruhela] When I first bought the car, there was such a problem. I cleaned the injectors, it sounded like it was burning.
When I bought the car, I changed the injectors, but I cleaned it up and adjusted the spraying after Egr. Smile
08.05.2020 20:29 # 13
ruhela
If your spray settings are bad, black smoke throws, my teacher had the same problem with me.
08.05.2020 20:29 # 14
Popomundo
I think the cancellation of Egr relieves the car but does it increase fuel consumption yet?
08.05.2020 20:29 # 15
Orcun.Dmr
The water plug in the block exploded recently, I removed the turbocharger, the exhaust manifold while I disassembled it and cleaned the parts I disassembled. Big smile In addition, max. I saw 155 km where I did 135 km and there was still an increase in performance I still don't understand. LOL Thank you very much for your help, I will need your help again with the new topic. Smile
08.05.2020 20:29 # 16
Orcun.Dmr
Unfortunately, after I have serviced my car, the smoke evacuation event started again. While the vehicle is running at idle, I press the gas until it reaches 3,000 cycles (it does not smoke until 3,000 cycles), when it comes to 3,000 cycles, it removes blue smoke from the exhaust when I pull my foot off the gas. When the cycle falls back to idle, I press the gas all the way (until the cycle is cut), it changes from blue smoke to black smoke and leaves a mark on the asphalt (which means it beats too much). The turbocharger makes malfunctioning whistles, its turbines are curved, and the shaft has a gap. Egr cancel. Do you think the smoke from the turbo is throwing smoke, or because of the oil. Let me add that there is no oil reduction and blowing. orçun.dm is 2018-01-26 02:27:35
08.05.2020 20:29 # 17
Orcun.Dmr
Seriously nobody knows or guesses in the huge forum? I hate the smoke of the car, and now I wash it and put it in the garage and run it with my father's car. I started to cool off the vehicle just because it was blowing smoke.
08.05.2020 20:29 # 18
pusutr
It may be time for turbo to change. My 206 was too. The turbocharger was using oil in the manifold, therefore, blue and black smoke was blowing.
08.05.2020 20:29 # 19
peugeot murat
If you look at the injectors first, never mind, if it is clogged, the transition will drop and when I get it, you say that I changed it when I bought the injectors at 50 thousand km.
08.05.2020 20:29 # 20
Orcun.Dmr
[QUOTE = pusutr] It may be time for the turbo to change. My 206 was too. The turbocharger was using oil in the manifold, therefore, blue and black smoke was blowing.
Was there any oil reduction in your vehicle?
Page : / 2
