my car is always overheating: (((
08.05.2020 17:05 # 1
nermin
It has not been a week since (206 1.4 fever) is constantly stopping on the screen, the temperature was 130, I gave it to the service, they did it on Saturday, I stayed on the road from the service yesterday, and the smoke came out, I took myself to the right, I found the repairman, I changed the thermostat, he went to the house again, I stayed in the smoke again without going 5 km connecting to the device in the repair, there is no problem anywhere but the fan is starting up too late. "border =" 0 "alt =" Cry "title =" Cry "/> "Cry"
08.05.2020 17:05 # 2
MagicPerformance
How many models of vehicles, how many kilometers of engines have been done before? I will help if you can give a little more detail.
08.05.2020 17:05 # 3
nermin
2007 model 75000 km before, there is an accident before me, so now the gearbox is broken, it is not known what the dioles are from it
08.05.2020 17:05 # 4
berk2309
I think the tool is automatic & nbsp;
08.05.2020 17:05 # 5
nermin
Yeah
08.05.2020 17:05 # 6
berk2309
The escapade of the sanctuary may be clogged. It may be overheated. What they said to you is exactly what you said.
08.05.2020 17:05 # 7
nermin
frankly, because I am a woman, I do not understand anything.
08.05.2020 17:05 # 8
berk2309
if they open up your belief, they should know the heat in the person who makes the worst figure like 2500 lira, and cannot do it & nbsp;
08.05.2020 17:05 # 9
nermin
money is not a problem, where is the problem, saying that I stay on the road, I'm not going to get into the car with fear anymore
08.05.2020 17:05 # 10
berk2309
If there is nobody to be interested in the press of the car because they stay at the masters, they say, let's put the engine to zero, to make money :)
08.05.2020 17:05 # 11
nermin
what will happen to my car i want my car "Cry
08.05.2020 17:05 # 12
If you do not understand, deliver the vehicle to the authorized service.
08.05.2020 17:05 # 13
nermin
I will take it to the service industry, which can not find the problem in the car service anymore "Disapprove"
08.05.2020 17:05 # 14
oozcan42
I think before looking at the transmission, take a look at the radiator and then the circulation pump, respectively. The second thing that comes to my mind is that the engine has to be overloaded as a result of the transmission failure. In a similar situation, when the clutch lining reaches the end point in vehicles with manual gears, the engine runs at high speed and overheats although the vehicle does not accelerate.
08.05.2020 17:05 # 15
GiTaRRa
you can not serve well, it is deemed to have been made when you deliver it, and a description of it is required. The transactions made are guaranteed.
08.05.2020 17:05 # 16
soldiermertefe
the same problem was in my mind, including the service, the masters could not find the last one I did. I had a thin drain hose between the expansion vessel and the radiator. It was clogged.
08.05.2020 17:05 # 17
nermin
[QUOTE = GiTaRRa] If you say you can't service well, it is deemed to be done when it is delivered to you, and a description of it is required. The transactions made are guaranteed. DIV>
problem guarantee or nothing else, my only problem is that my car is not built before I can not go to work, crawl on the roads, there is no breakdown, they will do whatever they have found.
08.05.2020 17:05 # 18
Aziz
Pejo services generally prefer memorization rather than logic, I have been a pejo user for 6 months and went to the authorized service once, I do not go any more. They said that if the idling engine changes, they said it will be fixed, & nbsp; I said good, & nbsp; I didn't know if they checked & nbsp; the next day they said the vehicle was ok, I opened the ignition, gave 15 thousand cycles of gas and left the problem. I said it didn't happen, I said, unscrew it, we put it on, what we're going to do more, we don't give it up. He ordered tea, he did not ask for money, the problem was corrected. It is best to find ex-trades for each part of the vehicle separately.
Meanwhile, I am halfway to sign lady ..)))
08.05.2020 17:05 # 19
nermin
frankly, I took the vehicle to the familiar master, looked at it, couldn't find it, got nervous, took the car to the service, connected to the device, searched, searched, not found, came back to the master, every part changed, again, the same problem did not occur, meanwhile, the master got the head on seven already, I will solve the problem in this car, then he went to another service and he could not find them. If you find the problem in the service period, please let us know. " & nbsp; I have already cut off my hope, my enthusiasm has escaped because everybody told me to take it "Unhappy" & nbsp; so the signature
08.05.2020 17:05 # 20
Aziz
It was very interesting, if the accident was large, it may have caused permanent damage. Have you asked the advice of friends who commented here, did they look at the masters? For example, if they looked at the heat exchanger of the transmission, which is called by a friend, I did not know if they were looking at the radiator that our friend said, and then the circulation pump. Ask the question given here, let's help with friends. seconds) Toyota corolla temperature problem Approximately 15,500 results found (0,38 seconds) Opel astra temperature problem About 13,700 results found (0,41 seconds) Reno megan temperature problem - Approximately 10,900 results found (0,33 seconds) I called gogülda here you try. the difference is obvious there
Page : / 3
