my car flashes the oil lamp please help
08.05.2020 16:20 # 1
hikmet
sa first I wish everyone good luck.
my problem is my peugeot 307 1.4 petrol + lpg car after a certain mileage (average 5-10km) when my oil lamp flashes even at idle. it even makes a stop when my vehicle is turning right or left during the tachometer, so my oil lamp is blinking. I'm throwing, even if I do not interfere with the steering wheel of my vehicle, after 5-10km, it flashes in the idle, flashes. I do not have anything to do with this vehicle. Everything you can think of has even opened the butterfly box and checked it, but it's empty all the same.
I'm very bored with this tool now, or what if one of my masters helps me. Finally, some of my masters said they made krangdan.
08.05.2020 16:20 # 2
The sound of the vehicle changes a little while turning the steering wheel, because on the hydraulic steering wheel, a belt is placed on the engine that will be riding extra. Also, does this oil lamp burn problem at high speeds? if it does not, it is because it is about to stop from idling.
08.05.2020 16:20 # 3
the same problem was with me ..
my oil lamp burned when i pressed the gas it was interrupted i called the pejo service immediately he said to me:
my brother said don't move your car, your oil filter is clogged ...
it was like the man said, I changed the oil filter problem disappeared.
08.05.2020 16:20 # 4
[QUOTE = Burak.Bülbül] I had the same problem with me ..
My oil lamp burned, when I pressed the gas, it was interrupted, I immediately called the pejo service, he said to me:
brother, don't move your car, your oil filter is blocked ...
man As I said, I changed the oil filter. The problem disappeared.
allah allah oil filter clogged yaw .bak I've never met anything like that.
08.05.2020 16:20 # 5
emin15
1.4 gasoline engines often have problems with the cylinder head, exsanthropic caps are worn out.
08.05.2020 16:20 # 6
hikmet
(1.4 gasoline engines often have problems in the cylinder head, exsanthropic caps are worn out, oil does not hold the pressure oil lamp is lit solution cover change.)
< br>
do you think my cylinder top cover is making the top cover as we know it
08.05.2020 16:20 # 7
hikmet
"Direct Submission Time: Yesterday at 10:30 while the steering wheel changes the sound of the vehicle changes a little because in hydraulic steering a belt on the engine that will get an extra ride. But I think the question is that your vehicle's idle is falling and your vehicle has an air flow meter. Have you checked it? Also, does this oil lamp burn problem at high speeds? If it does not, it does because it is about to stop from idle.
Does not do at high speed.
