My Car Doesn't Work!
08.05.2020 15:09 # 1
Ako06
Hello friends. I said before my car 2002 307 xt. I'm going out by car, I'm going for a while. sometimes it doesn't work again when i stop and stop. A yellow light is on, I think the abs light. stop flashing or something. Çözemedim.
08.05.2020 15:09 # 2
Ako06
Why aren't you helping friends?
08.05.2020 15:09 # 3
307P
They will help when knowledgeable friends enter Gülme
08.05.2020 15:09 # 4
Doesn't it mean that it does not work or does it freeze or run? The abs light you call. Did you have a problem with the battery? Can you hit Mars?
08.05.2020 15:09 # 5
Ako06
yeah i think that abs light. it stays on. I can start, but it doesn't buy, it doesn't work. For instance, I went somewhere, for example, it did not work while coming back. Seven worked while holding the starter for 10-15 seconds.
08.05.2020 15:09 # 6
There may be many reasons for not getting Mars, but since the abs light also burns, I was stuck in the battery. Do you have a chance to try your car with another battery for a couple of days? If you know, change it.
08.05.2020 15:09 # 7
Ako06
If I try to try it like that, it should stay with me for a while. because this event has not been happening for a month. It happened a few times a month ago. He hadn't been doing it for a long time.
08.05.2020 15:09 # 8
I think that this kind of problem is not a simple situation. Especially in the long term, you may encounter serious problems. I recommend you to have the vehicle connected to the computer in order to diagnose it. So you have an idea about the problem. causing a larger problem.
08.05.2020 15:09 # 9
mehmet066
The only reason he says Stop Stop is that there is a problem in the car. Just because the abs light is burning, it is not the cause of burning, or if the room is on fire. I had the same problem, I put it on the computer in the service.
08.05.2020 15:09 # 10
tigerland
check the battery. It should already have empty expressions on it, if the part is green like a small round glass, your battery is in good condition. I recommend not using it this way.
08.05.2020 15:09 # 11
Ako06
It has been 2-3 months since we bought a car alone. When we first got it, we got it connected to the computer. no problem, they said it was fine. even this evening had happened when I went on a test drive.
08.05.2020 15:09 # 12
cakici9843
It wouldn't be good if you hold the starter for 10 or 15 seconds. induction coil may burn. If it works after that time period, there is a problem in the car's ignition system. I guess there is a problem with the induction coil that replicates the current from the battery.
08.05.2020 15:09 # 13
hhuzun
my friend is going to the engine with diesel or gasoline
Even if it is 10 seconds, you will finish the discharge battery.
; maybe there may be dirt in the pipe coming from the tank, and look at them
