My car does not work on LPG and petrol, my help?
08.05.2020 19:14 # 1
Erhan_Gti
Friends everything was normal (206 gti 99`) I wanted to take my car off tonight, I started the engine, the engine is spinning and it doesn't work. If this problem happened or someone who knows, please help us all good forums.
08.05.2020 19:14 # 2
sezar206
The same happened in Leon, the battery was broken. If a booster runs and runs, buy a battery.
08.05.2020 19:14 # 3
Erhan_Gti
the battery is zero like a monster, the starter is like gold, maşallah
08.05.2020 19:14 # 4
talip206
The Immobilaser in the ignition key may be broken. If you have a spare key, try running it with it. When it is faulty, mars starts but the car does not start. He was the first to come to my mind,
08.05.2020 19:14 # 5
As the aspiring friend says, there is a possibility of immodan. Also, if the lpg system's lights are not lit, it may be from the fuse. gasoline starter may not be caused by the gas pump.
08.05.2020 19:14 # 6
palet
You can think that your Crank position sensor is defective if the engine does not start even though it is wearing when you turn on the ignition in both gasoline and LPG. The ECU is unable to timing the correct ignition because it does not know the crank position.
08.05.2020 19:14 # 7
Erhan_Gti
friends, gasoline relay and lpg relay officially swimming in water, took full water and rusted in rusted insurance today, I removed the roles, cleaned them and cleaned them administrative. now it works but it is not very healthy. It does not work occasionally. How can we detect sensor failures?
08.05.2020 19:14 # 8
If there is oxidation in the cables, it is necessary to look at them first. causing contactlessness. You have to connect to PC. to see if there is a malfunction.
