my car does not work cold !!
08.05.2020 16:21 # 1
aopena
If they were working yesterday, my car did not work today but it did not work today but it was little cold but it did not work even if the battery was supplemented, but when I look at it, I think it is coal, I do not want to run it to industry, I do not want to run it, I do not want to run it.
08.05.2020 16:21 # 2
Engin Tepe
Don't hit, if it is close, take it to a vehicle, but if it is not close, take it with tractor or if you are sure of the defective part, if there is a familiar master at the door, change dynamo or & nbsp; coal etc.
08.05.2020 16:21 # 3
aopena
Also, when the starter is running out of the battery, the electricity has gone and went, the indicators are playing suddenly. Do you want to get rid of the problem? If the glow plugs do not work, I did a booster battery, it did not work again. It gives a nice starter in the first place.
08.05.2020 16:21 # 4
My friend has the same vehicle of your vehicle and experienced the same problem, nothing will be afraid of the indicators, but I think the problem is that the battery will never start from the starter engine. If 60 amps are used, use 60 amps, if 60 amps are used, use 72 amps. It works in one starter when winter comes. Check the heating spark plugs.
08.05.2020 16:21 # 5
aopena
Well I did a booster battery 12 v 180 amperes did not run it.
08.05.2020 16:21 # 6
[QUOTE = aopena] well I did a booster battery, I wonder if it didn't work for 12 v 180 amps .. [/ QUOTE]
If the cable you are supplementing is not of high quality, or if it is too long or too thin, there may be problems such as this. that means.
08.05.2020 16:21 # 7
aopena
Well, I will fix it as soon as possible. I want to ask one more thing. My troubles do not end. My vehicle has started to be very short. it burns faintly, I don't want to find any problem in those who do not have any authorized service in my environment, I do not want to find any of those who understand it. I wonder what happens ..: /
08.05.2020 16:21 # 8
berk2309
Replace diesel filter. Maybe it has clogged air or you have received bad fuel. check the spark plugs & nbsp;
08.05.2020 16:21 # 9
aopena
Where exactly are these spark plugs of the vehicle, in fact, when the diesel comes down to the quarter, sometimes the engine sign comes out and gives an error. I think you may be wondering what happens when it comes to quarter, why does it take air when it is full?
08.05.2020 16:21 # 10
I do not have any idea about the problem, but for the sake of God's sake:)) "Embarrassed" afaruk307 2011-11-12 18:39:30
08.05.2020 16:21 # 11
berk2309
I don't know your partners, teacher & nbsp; Replace the diesel filter or something & nbsp; change the gasoline you use, using the euro euro & nbsp;
08.05.2020 16:21 # 12
aopena
euro diesel filter vs new already & nbsp;
08.05.2020 16:21 # 13
Kemanyak
Look at the diesel pump. There may be buoys stuck on the float. I think the problem is in the fuel supply system. I recommend you to try it with a new battery because if a sector in the battery is bad, feed it with 2000 amps if you want, the vehicle will not buy. & Nbsp;
08.05.2020 16:21 # 14
aopena
But when the car that has been working until yesterday has stopped working in the morning, diesel fuel is close to a quarter in the warehouse. I tried to run it with 200 amps would it be harmful & nbsp; aopena 2011-11-13 10:46:55
08.05.2020 16:21 # 15
Kemanyak
No harm.
