MY CAR DOES NOT WORK
08.05.2020 17:20 # 1
stankovic2012
FRIENDS HELLO ... I HAVE 2005 307 HDI. I RECEIVED IT IS 1 MONTH. COGU TIME MORNING BUT IN THE DAY, DE & nbsp; INTERMEDIATE SEARCH & nbsp; DOES NOT WORK ... THE STARTER BASIYO BUT DOES NOT WORK .... THE BATTERY IS NEW, THE ENGINE FILTER HAS BEEN CHANGED, THE INJECTIONS FALAN, THE SERVICE HAS BEEN CHANGED, THE SERVICE IS 700 TL. OR IN ADANA & nbsp; THERE IS A PROBLEM IN PEJO SERVICE, I HAVE A SIGNIFICANT OR IMMOBILIZER SYSTEM, WHY I DO NOT UNDERSTAND, I DO NOT UNDERSTAND, THIS IS THE SUBJECT TO THIS; MORE THAT WAS NOT WORK IN THE MORNING OF THE CONTACT ON WHAT FAN UFLÜYO, WHAT IS THE AIR CONDITIONING LIGHT .... PLEASE HELP IF YOU HAVE ANY KNOWS?
08.05.2020 17:20 # 2
Serkan
It may be caused by fuel pump, also the fan will not blow when the ignition is on, the air conditioner light will not blow when the vehicle starts. When the vehicle is not running, try tapping the fuel pump with a wrench or pliers.
NOTE: Capitalization in the forum means shouting and is prohibited.
08.05.2020 17:20 # 3
stankovic2012
It was true that you said yes, SERCO05, so when the ignition was on, the fan did not blow and the air conditioner did not burn in the heat, I just frightened that the car went down a little while ago .... without being a thing, I am afraid that the fuel pump will not start again: (& nbsp; & nbsp; where is the fuel pump? When I open it, I do not know where exactly, if it does not work, let me do what you say tomorrow morning ...
I will take it to the service again tomorrow 3 I am going for this problem, they have changed things, I said 700 TL, now I will give money, I will complain if it does, adana pejo service, ,,, i am wrong, but due to the same error 3 times the car is taken to the service ... hı bide, bidim planting service for the second time & nbsp; they cracked the windshield, we discussed a little there then replaced the new windshield ...
08.05.2020 17:20 # 4
Serkan
The fuel pump is not in the engine part, above the fuel tank, under the rear right seat, lift the seat, there is a big black cover, pull it out, pull it out immediately, you see the pump directly, there are sockets, hoses or something, when the vehicle is not working, click something like wrench and pliers, it may be stuck, the problem is from immobilizer though it gives an immobilizer engine fault warning on the screen.
08.05.2020 17:20 # 5
atlasbm
Adana Dortler Shuttle festivities to full houses. I think it is useful for you to go to a special service where you trust its mastery.
08.05.2020 17:20 # 6
stankovic2012
PROBLEM KEY, WRAPPED AND WORKED WHEN I RUNNING THE KEY ... THIS KEYS WERE CHIPPED IN THE FRONT SIDE OF THE CHIP WHICH DAMAGED FROM THE KEY FROM THE WRONG FACE
