My car does not eat gas in rainy weather stops
08.05.2020 20:21 # 1
Arel
Hello everybody, I just joined you.I have my problem, I have 206 1.6 lpg roland garros owner, it has been 2 months, but I have done all the maintenance, but the car does not work, especially when it is working in rainy days or when it is washed with water, it carries gas and it seems like it is choking. If I take my foot from the gas, it turns back to idle.
08.05.2020 20:21 # 2
sdttn
Check the air filter. It may be taking water.
See also the ignition coil, you can spray the water around with a spray and observe the change in the engine.
sdttn 2017-05-19 22:21:17
08.05.2020 20:21 # 3
Arel
I checked the teacher, even there is no humidity in the air filter. We noticed that the socket that enters the motor brain has no contact with the cable junction. Stopping does not eat gas, it stops or works when it plays with this cable.
08.05.2020 20:21 # 4
talip206
https://forum.peugeotturkey.com/forum_posts.asp?tıd=41099&title=yagmurlu-havada-soguk-motorda-gaz-yememe-titr Game
I had a similar problem appeared in the coil problem
08.05.2020 20:21 # 5
Arel
When I do not carve with the end of the socket I said it takes only one star. I think this would not happen if it was in the coil.
