my car does not crank help
08.05.2020 14:17 # 1
friends, my vehicle does not start, the battery is full, the screen lights and other lights are on, it works, it works, the horn is pressed, but if you press the starter for a second and cut off, I would be glad if you help Kundu 2010-06-22 13:02:36
08.05.2020 14:17 # 2
selcukcivelek
There is a problem with the starter, I do not think there will be any possible spark plugs or something but it is from the starter .. If you contact the service, they will help you
08.05.2020 14:17 # 3
I will take it if it works :)
08.05.2020 14:17 # 4
You can run it by hitting the last hit. but I do not recommend. first try to control the starter cables. Check the polarity of the battery. If there is a loosening of the marsin plant and the battery, it may be cut because the current is not good.
08.05.2020 14:17 # 5
I tried, but it does not happen. There is no problem with the cables. I tried it with a spare key. It was the first time this event started.
08.05.2020 14:17 # 6
insert the battery, try it with a battery that runs on another vehicle. Let's see what happens next?
08.05.2020 14:17 # 7
I ran it by knocking it, then I stashed it and run it over and over again.
08.05.2020 14:17 # 8
Psh
Have the automatic starter check because it will visit you again soon. The price of 307 valeo around 90 lira. Workmanship is where you go. Psh 2010-06-22 14:42:06
08.05.2020 14:17 # 9
okankrgz
Do you have plumbing in your vehicle? You know, as I said to my vehicle, because he was on the run, you run after a long time, but something annoying
08.05.2020 14:17 # 10
the installation is full, but I turned off the ignition without turning off the trace. Could it be because of it, but the headlights are on and something interesting
08.05.2020 14:17 # 11
selcukcivelek
There may be electric leakage in your vehicle, alarm or something I do not know after all, may be zenon or something like electricity. If you burn cars, I wish I changed the starter engine, it is not cheap, because ... get well soon
