my car burns a lot
08.05.2020 15:00 # 1
sinan0343
mrb friends I have a 206 x-disgn 2005 model car, but it burns 250-300 km per km.
08.05.2020 15:00 # 2
serkan24577
You are using the petrol, you will burn the car, of course, the normal values of it will be your vehicle, of course, lpg your head will be comfortable.
08.05.2020 15:00 # 3
sinan0343
so which brand of LPG would you recommend ... how much would it be mall ...?
08.05.2020 15:00 # 4
GiTaRRa
Believe me, even my friends car is small 1.4 engine but it is not believed that it burns between 250 and 300. but I have never seen Qik in the tube bidet pocket I should think of course ...
08.05.2020 15:00 # 5
serkan24577
[QUOTE = sinan0343] so which brand of LPG would you recommend ... how much would it be a mall ...? [/ QUOTE]
I am using diesel :) lpg ci is asking friends, but brc is good, it was around 1.250 but there was a big decrease in fuel
08.05.2020 15:00 # 6
GiTaRRa
Let's get it done, is this okay with the engine? I know that I have it. For example, I know that the timing set of the tubular vehicle changes at 30 thousand. If it is true, it means that the engine is so tight ... but it will contract us in fuel, I will burn this vehicle, a jerry can of petrol and yaaaa :)))
08.05.2020 15:00 # 7
sinan0343
You're right, brother .. duh
I was surprised at my nappy too
08.05.2020 15:00 # 8
eneslan
[QUOTE = sinan0343] mrb friends I have a 206 x-disgn 2005 model car but it burns 250-300 km per km.
you earn per unit price rather than fuel.
08.05.2020 15:00 # 9
only_ozyy
Well, my 206+ drinks the gas like water ... normal fuel is your crazy boy ... these vehicles are not at all tube-like ... there is no room in the trunk ... they are not compatible with the place ... they would expect a discount in the best gasoline
08.05.2020 15:00 # 10
serkan24577
[QUOTE = only_ozyy] I mean, my 206+ drinks gas like water ... normal fuel is your crazy boy ... these vehicles are not at all scuba ... there is no room in the trunk ... We would expect a discount on gasoline
we die again, gasoline price does not decrease :) Star
08.05.2020 15:00 # 11
qEccE
friends do not touch the 250-300 burns, no need to touch the tube, I sometimes measure 260-270 odd in the tube :) though in the last two tanks it was 212 kurus in one, but this very unbalanced tube work was extra care in the bidet. I think the license to give the bidet 1250 tubes will be 1500 when we say this
08.05.2020 15:00 # 12
deniz_206
I am troubled with fuel too, my friends are burning so much.
08.05.2020 15:00 # 13
driving a car in this period is crazy, I use diesel, but even you know that it comes to me.
08.05.2020 15:00 # 14
only_ozyy
Well, as these cars walk, we don't have anything to the economy of our country ... we pay tens of taxes for a vehicle .... tax money for everything ... but we are obliged to enjoy it :)))))
08.05.2020 15:00 # 15
Sir, the 1.4 engine of the vehicle had 106 quicksilvers with the same engine. It does not fall below 350. Especially after this hike, even 400 sees easily. The important thing here is how many liters the vehicle burns. but if you see a figure like 250, you will regret the vehicle. You just finish the tube job lie car. I have been using peugeot for 6 years and it has not passed my mind. Unfortunately, we cannot get rid of these problems with this gasoline price. Just like the price of diesel approached gasoline. When the use of tubes increases, its price will increase.
08.05.2020 15:00 # 16
sparrow
slm folks, I also have a quicksilver, making 100 km and 310 km, I was the only one in my car, I thought I didn't think about the tube, but this car is too much fuel
08.05.2020 15:00 # 17
erdal
atiker is good both price and harmony ..
08.05.2020 15:00 # 18
Let's get [QUOTE = GiTaRRa] okay, is there no harm in the motor? I know that I have it. For example, I know that the timing set of the tubular vehicle changes at 30 thousand. If it is true, it means that the engine is so tight ... but it will contract us in fuel .
How did I miss this topic?
If my friend is lpg to you, thank you for 30,000 triggers, thank you, thank God.
Speaking with mouth, I do not peel it. Let the man who does not understand the LPG from the screw of the car, is very angry. My words are out of parliament ...
Look, when my brother uses LPG, the vehicle's truck will not change before. lpg engine kasmazzz. In addition, since the octane number of lpg is higher, it operates more beautifully without vibration and knock than gasoline. With LPG, the spark plug different from the original spark plug of the vehicle can also be used. More special spark plugs for LPG in the market are developed and sold. You'll be late to break the engine. If it is adjusted properly, it will not damage the engine. The engine is not harmed when it does not perform maintenance while working with gas, but it is harmed by the lpg. In this case, I show the example of the falcon that was used in a taxi. Let me give one more example. Dacian logan 1.6 8V 90 hp taxi driver, which was used carefully, did not touch the engine at 440,000 km, even though he had an accident vehicle. What should I say more ... but if the vehicle is used as a poor or rich mixture by burning the breakdown light continuously, valve problems in the long run may be overcome. In the case of this, it does not cause any other damage to the lpg engine.
In addition, the maintenance of the LPG changes 2 filters at 10,000 km once. Room is 30-40 TL. others are the maintenance of the engine itself. The lpg engine has no special maintenance ...
Although they do not know my reaction to those who speak unconsciously, they are speaking because I am crazy. The human beings are misleading. millet is afraid of lpg ...
08.05.2020 15:00 # 19
In his mind, there is no harmony. The ones who called it found a reason for themselves because they couldn't do it. There is a lot of pug on the market that doesn't work properly with the LPG malfunction. did they come from outer space?
but they have their own owner in the car, sogutan pugs, from having a problem that does not end in any way. this situation has many different reasons. but make sure the water is not in the engine. assembly errors, setting errors, maintenance notices and unconscious use ...
By the way, if you wait for the price of gas to fall, your life will pass :)) it is painful but the truth is: (((
08.05.2020 15:00 # 20
well friends bnm white angel burns 700kr i wish i burn 250-300kr i never get down Sırıtma
Page : / 2
