my brake problem
08.05.2020 16:58 # 1
scepter
good day;
friend I bought 0 cars but I have a problem because the car's brakes are very sensitive. can be helpful & nbsp; if they have good tactics or have their own tactics & nbsp; that is, even if I press the brakes very sensitive, hard braking is going on & nbsp;
b>
08.05.2020 16:58 # 2
hcbank
First of all, God does not cause any trouble, as you get used to the vehicle, you will not have any problems, but if the vehicle is braking too hard even with a milimeter touch, the vehicle will be taken under warranty under the warranty.
08.05.2020 16:58 # 3
scepter
[QUOTE = hcbank] first of all, good luck, no accident, no problem as you get used to the vehicle, but if the vehicle is braking too hard even with a milimeter touch, the vehicle is under the warranty, take it to the service, look at the service 0 vehicle die cannot be faulty, simply say the problem with brake centers or pedal settings. solved & nbsp; [/ QUOTE]
okdr not hard I think it was because of the old car
08.05.2020 16:58 # 4
You need work. Brake stiffness of each vehicle is different. The same model may even differ between vehicles. & Nbsp;
08.05.2020 16:58 # 5
sezar206
Every car you get used to is different. My brother had a megan, his clutch was like a stone.
