my amp + sub choice
08.05.2020 18:08 # 1
korkusuz202
Hello friends, I want to ask you, are these two compatible?
KENWOOD KAC-M846 Amplifier
Product Type: Amplifier, Number of Channels: 4, Capacity at 4 Ohm: 4 x 60 W, Maximum power: 720 Watt, Manufacturer's Warranty: 2 Years
SONY GTX121LC 12 inch 30 cm 1000 W
RMS power: 300 Watt, Maximum power: 1000 Watt, Sound pressure level: 86 ± 2 dB, Frequency Range: 32-1000 Hz, Impedance: 4 Ohm,
08.05.2020 18:08 # 2
EmSul
When it comes to compatibility, the amplifier is insufficient in feeding but you still get satisfactory performance.
08.05.2020 18:08 # 3
barishrocker
I would say mono forehead if the sub is connected to the amplifier only. Apart from that, as your friend says, the amp is inadequate in feeding.
08.05.2020 18:08 # 4
korkusuz202
I do not want that much professional, how happy it is for me if the bass strokes will be felt in a noticeable manner without the sound quality deteriorating
08.05.2020 18:08 # 5
korkusuz202
two of them 420 TL, I ordered zero because I will buy it in installments
08.05.2020 18:08 # 6
Feyribas
Hodja, good luck already. But his amp is inadequate. Peak value of 720 watts amplifier. It will not satisfy. It only makes a roar in the beginning, no emphasis. It will be healthier if you use the amplifier for 6x9 speakers or mid suits.
http://www.mediamarkt.com.tr/mcs/product/sony-xm-gtr3301d-1100-w-1-kanallı-amplifikatör,103452,465582,854406.html?langıd=-14
You can use it for bass ... A satisfying and press-compatible amp ...
08.05.2020 18:08 # 7
korkusuz202
Here we are running 1200 watts sub with 760 watts pioneer http://youtu.be/kusHONMUjWw korkusuz202 2013-12-17 22:20:41
08.05.2020 18:08 # 8
Feyribas
Sir, the event you mentioned is the GM-5400T amplifier. It has 380 RMS output in 4 ohms ... If you connect it except for the bass speaker, it has a peak value of 760 watts ... So it's a good power amplifier ... Meanwhile your orders have arrived? Did you install it?
08.05.2020 18:08 # 9
korkusuz202
No Master, I haven't shipped yet. If I already assemble it, I will add the subject to the site.
korkusuz202 2013-12-20 14:12:32
08.05.2020 18:08 # 10
Feyribas
Come on, then ...
08.05.2020 18:08 # 11
korkusuz202
products arrived today and the result is GREAT !!!
Aracımda
Prevents Kenwood component 300 watts 16.5 speakers
Rear Kenwood 500 watt S6993 5 way 6x9 Oval Speaker
Amplifier Kenwood 720 watt 4 channel Amp
Subwoofer Sony 1000 Watt Slim
video is not very clear, but sound and bass are very good friends.
http://www.youtube.com/watch?v=iak6a0gfnrs&feature=youtu.b to korkusuz202 2013-12-27 13:21:47
