My 407 vehicle problems
08.05.2020 20:43 # 1
sckinahmet
to sckinahmet 2018-06-27 14:04:34
08.05.2020 20:43 # 2
Aleyküm hi ahmet welcome to us.
1- There is no solution other than making a change for the problem, you will either get out or get you out of China. alixpres link
2- When it comes to the problem, bro related to the lpg settings, you have not come across a master of the level, make the lpg transition temperature 35 degrees min. Or use gasoline until the engine warms up a bit and then LPG is not a problem late. Or you should use a car with a minimum of 150-200 km and go to a place that makes adjustments like a man. Usually, masters perform standard calibration. In fact, it is the healthiest to do according to the map values in motion while adjusting the LPG.
3- The cd reader may be go-away or it may originate from CDs. You can do aux, the cable that I gave link will work. If your vehicle is not on aux, you will have to open it in a place with peugeot software.
4-I couldn't visualize a picture in terms of helping it be better than loads.
08.05.2020 20:43 # 3
maximusti
Can't we solve this screen wiping by putting the thermal paste used in the processors of the computers and the plates behind them?
If you check from the tape brand and series, it is likely that the apparatus shared by soner will work. You can plug it into cd changer output and use it.
4. I guess they also stole the ceiling bar, either someone very curious about the original of the ceiling has been removed, or there is a problem with it, he has removed it for you. I think the following product:
08.05.2020 20:43 # 4
sckinahmet
to sckinahmet 2018-06-27 14:05:26
08.05.2020 20:43 # 5
necmettinn
[QUOTE = sckinahmet] Thank you for answering, I'm entering from the phone now
The piece I mentioned in 4 is on the door, not on the ceiling
https://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-otomotiv-ekipmanlari-aksesuar-tuning-peugeot-407-krom-yan-kapi-citasi-4-prc-2004-2010- 502607723 / detail
If you think of the product sold in this link, do you think these products are of good quality? Prices are very cheap because [/ QUOTE]
If you are talking about the glass edge nickel lath, I know that the complete set is around 75TL. It is also available on sahibinden.com ... Aux cable does not need to be of very high quality as it is only used to transfer the sound to the inputs of the tape. There are necessarily high quality double shielded etc. etc. etc. But I think there is no need to pay a lot of money .... The reason for the affordable price in Aliexpreste is that the craftsmanship in this legless Chinese is so cheap that you can get your material here and send it to you as you have assembled the manufacture of the goods for almost 5/1 price ... aliexpreste I know the reason why it is suitable is that the workmanship is cheaper than the quality ... For example, I ordered a rear view camera with a front camera registered rear view camera and the cost is 109TL. workmanship belongs to me :) I am thinking of opening and sharing a new topic with the assembly steps .... Here they only provide the parking sensor for that price :) :) :)
Good evening with the sentence ....
