My 407 Car Thermostat Cracked and Engine Is Being Built
08.05.2020 20:51 # 1
serdarr4
Friends, last week, my peogeot 1.6HDI vehicle started to pull off while driving uphill. I stopped and looked, the fan was running and the temperature was normal. I continued my way slowly without stopping the engine. Meanwhile, the malfunction lamp etc. did not light up. After driving for about 25 km, the engine oil temperature rose suddenly and the trip computer stop light came on. I pulled right and stopped. Water vapor came out of the hood when I got off.
When I opened and looked at the hood, I saw that the vehicle's thermostat cracked and left the junction. It was about 5km from my house. I combined the thermostat with the wire in my toolbox and continued on my way by adding water. There was no abnormality when the vehicle was going. The industry was about 30km away. In this way I came to the industry to add water. Only 3km from the industry remained that the heat jumped, the vehicle stopped. I got off and completed the water again. This time it didn't work.
I took it to the master with the tractor. The engine will land, he said. The injector nozzles burned when the engine came down, the edge of the engine lower block was broken as much as the lentil grain. The master said that the expense would be high. He produced a figure like 10500tl. I took the car from there and took it to the peogeot master. He examined it thoroughly and made an account. He said that the bottom blog and the cylinder head will be grinded, and the bottom blog will fill the top part of the piston, which will be as much as a small piece, of course, the pistons would be fitted with zero. injector maintenance will be done, said the total cost will play between 5500-6500tl. I will have a total cost of 7000 TL for turbo maintenance at 900 TL. Of course I will be charged on the credit card.
I love my vehicle, we will compel this cost. First of all, my advice is to turn off the peogeot vehicle when it says about the engine, pull it to the right, take it to the master. Don't just look at the harness of your vehicle and say everything is fine. The master will not rise when there is no water, he said.
My question is that I have encountered a situation like this before. Will my vehicle give efficiency after that? How much does the average go when the engine is built this way? Peogeot cars cost too much. I know the friends in the forum have been up to 1 month. When I bought it, I trusted the engine as 81%. I think I like to ride my vehicle with love, but if such a problem gives me another problem, it will cause me financial difficulties for now. Your thoughts as a realist are very valuable to me. Best regards. I apologize to the moderator in advance if I did not open the subject to the right place.
08.05.2020 20:51 # 2
GokhaN
First of all, I do not think it will get the same efficiency from the vehicle if it is done by a good master.
08.05.2020 20:51 # 3
necmettinn
Get well soon...
08.05.2020 20:51 # 4
get well, my teacher experienced the same problem. He spent some 10,000 rubles, but he could not get the engine out as before. The master is very important in this regard and be careful about the original or high quality parts of the fitted parts. A good and knowledgeable master will take him again for a long time.
08.05.2020 20:51 # 5
x571
[QUOTE = serdarr4] Friends started to not shoot my peogeot 1.6HDI car on a hill last week. I stopped and looked, the fan was running and the temperature was normal. I continued my way slowly without stopping the engine. Meanwhile, the malfunction lamp etc. did not light up. After driving for about 25 km, the engine oil temperature rose suddenly and the trip computer stop light came on. I pulled right and stopped. Water vapor came out of the hood when I got off.
1- They have already sold you bad vehicles.
2-a little bit of your fault. When you had trouble, you would pull the right and call the hammer. it would go up to 200 lira at most, but the vehicle would not be that much.
3-If there is a sale instead of repair, look at the crate engine, maybe it will also come out.
4- Do not hurt someone else's life, get it repaired and sold enough to handle it.
08.05.2020 20:51 # 6
serdarr4
My Peogeot 407 vehicle was delivered after 15 days. Cared for.
Engine blog repair, pistons, valves etc. were completely reset. 2250tl
Engine full seal maintenance filters, workmanship and other parts: 4000tl
Engine injection full treatments: 1900tl
Turbo shaft replacement and repair kit full maintenance: 900tl
Approximate engine cost went around 9000tl. I received the vehicle 2 days ago. I traveled about 400km. Traction is low for now as the piston liner will take time to get used to. They showed how they solved the problem in the vehicle engine block. They took a photo or something. The remaining shirt than the original was placed inside the shirt of the vehicle. looks like it was stronger than before. My efficiency is good for now, I will inform you about the situation in the future.
I was in the industry from morning to evening on the day my vehicle was assembled. Wait at the beginning of my car, I drank tea and coffee. I really liked the engine workmanship. He smiled in me. I also thank the friends who share their thoughts.
08.05.2020 20:51 # 7
Hodja, first of all, I hope it does not cause any other problems and masters stand behind their workmanship. Not a small amount of 9000 TL. In fact, if you can upload those photos, it will be an example for those who have trouble like you. Thank you very much in return.
08.05.2020 20:51 # 8
KILIC
[QUOTE = serdarr4] My Peogeot 407 vehicle was delivered after 15 days. Cared for.
It was great. Do not be afraid of the workmanship if it is silent, nothing will happen. I think that if the craftsmanship of the master is good, he will stand behind the work he has done. I hope you use it without any trouble and trouble.
08.05.2020 20:51 # 9
serdarr4
Friends 407 cars have been repaired. Engine grinding - injector maintenance - turbo overhaul - brake pads - timing - labor etc. kept about 9200TL. I made about 3000km of road after it was built. Maahallah it was perfect.
08.05.2020 20:51 # 10
maximusti
Get well soon,
the expense was salty, but at least it was worth it.
08.05.2020 20:51 # 11
x571
[QUOTE = serdarr4] Friends 407 cars have been repaired. Engine grinding - injector maintenance - turbo overhaul - brake pads - timing - labor etc. kept about 9200TL. I made about 3000km of road after it was built. Thank you, it was perfect. [/ QUOTE]
If it was nice, no problem. I hope it won't cause any problems in the future. 407 is a good car. People who give 90 thousand TL and buy 2 air-polo polo.
08.05.2020 20:51 # 12
I am glad that it has improved, my teacher, Allah. You use trouble-free trouble.
08.05.2020 20:51 # 13
Crayzmetin
Get well soon. Trouble-free trouble-free driving. Where did you get it done as a service?
08.05.2020 20:51 # 14
keoturk
a similar problem happened in my toyota avensis car, while it was snowing on the long road, the thermostat failed, the engine block cracked. oil was mixed into the engine water. I made my own master. I used it for months after having it done. I had no problems. There was no problem going on the traction. then i sold to change the model
08.05.2020 20:51 # 15
LUDACRIS
There is no pedestal because the Peugeot deteriorates quickly.
Everywhere you spend your mind in our country, you are unconscious people
Tools for becoming scapegoats. When I got 407 in time
I have been a member of the forum to get information and I have it for 3 years.
It did not cause any trouble or trouble. But our clever person
You can get 407 for 30 lira but be flawless.
Even if the mother of the engine cries, if there is little paint, there is no paint
LED headlights bass amplifiers 55 sidewall tires what are they ..
Using 20w-50 oil.
I am not upset that the car broke down
If you call the tow truck for the first time and give it more than 30 lira, then 10,000
It wasn't going to come out, but whatever I said was empty :)
Nothing as a percentage of the engine, it will measure healthy in the country
The number of Dyno is 5 but. Neither package is known nor researched.
Comfort is not taken, for example, but it is multi ok in the bay :)
Ooo screen exists. If we ask about the differences, they don't know etc etc
I hope your experiences will be a lesson for you.
08.05.2020 20:51 # 16
gayetnormal
First of all, get well soon. A similar situation would have happened to me a little more, but I was a bit more lucky. A water distribution pipe described as "octopus hose" in our cars last winter was broken and the car drained all the water. Now the part I understand is very simple.
At that time I was on the move and my heater was slowly starting to heat. I was going with about 120 and it was 6 degrees outside. The heater suddenly started blowing cold and I could not understand what it was, I went calmly for 2 km. It was abnormal that it still did not heat and I pulled over and looked at the engine water. there was no water left. As the weather was cold, I thought I would not see anything on the temperature hand (which should not have been shown when there was no water). I immediately went to my mechanic by adding water. we replaced the hose and continued. I still have a problem that remains since that day. My car decreases the water to half the expansion tank in 2000 km from the circulation. but I will get it done this time. If the desired temperature or coolness value is not obtained during heating or cooling, it is my advice to look at the water of the vehicle first.
I advise you to look at the oil and water without starting the engine while getting into the vehicle. I think we can get small signs to avoid a big expense. again get well soon.
08.05.2020 20:51 # 17
whisky
[QUOTE = LUDACRIS] There is no pedestal because the Peugeot breaks down quickly.
Using 20w-50 oil.
[/ QUOTE] You'd beat him up. For example, I used executive black in 2009, I am using comfort for 2 years now. why not? Based on what are you saying? There are differences such as side seat electric seats etc, one is 60 horsepower and the other is 160 hp. he has nothing to get on. There is not much difference between the two packages between comfort and executive or premium. the difference is entirely a matter of personal taste. your empty conversation is yours. it is a shame that you did not say to the man oh
whiskey 2019-01-15 13:54:20
08.05.2020 20:51 # 18
LUDACRIS
[QUOTE = whiskey] [QUOTE = LUDACRIS] There is no pedestal because the Peugeot breaks down quickly.
Using 20w-50 oil.
You're empty talk :) first learn the differences, then
If you can be level, we will discuss. LOL
08.05.2020 20:51 # 19
whisky
[QUOTE = LUDACRIS] [QUOTE = whiskey] [QUOTE = LUDACRIS] There is no pedestal because the Peugeot breaks down quickly.
Using 20w-50 oil.
[/ QUOTE] He talks about his level of posts. are you a joke Take a look at the writing style of the man's topic and look at the message you posted, oh no worse than that. we are not going to learn the level from people like you. Everybody buys the vehicle they want, and it doesn't care about you. He uses it as he wishes, he pours gasoline, burns it. Do not be rude, nobody's doing what you do.
whiskey 2019-01-16 09:01:47
08.05.2020 20:51 # 20
Using 20w-50 oil.
Please do not say such things to others, it is a situation that can happen to everyone, and even if it is possible for everyone to understand from the vehicle like you or us, it is not necessary to be used, and it should not be used in such forums, and people who are looking for help will not cool them from such forums. it can even go to different situations and go to profanity and quarrels. I warn you again, if you are going to continue with such comments, please do not write any comments or come in the forum. Our dear members, you should close here on this matter. Certainly such comments will be deleted directly from now on.
Have a nice day
Page : / 2
