My 407 1.6 HDI is very confused ...
08.05.2020 20:06 # 1
407 ERHAN
Hello again, I have shared this issue with my dear friends before, but I am only trying to find a solution from my internet here, because there is no good master or service from peugeot in my city, so I do not want to tamper with my car, both in terms of engine health of my vehicle and monetarily. The problem with me is that, when I first started my car, it was not very intense for about 1 minute, but it was throwing a noticeable bluish smoke, then it was cut off, there was no going on the road, it was because it burned fat, but this situation has been going on for about 1 year and there is no shortage in oil. , on the contrary, fuel consumption has increased a lot, maybe you do not believe it, but the city burns 40-45 cents comfortably, and in normal use, it also turns on the engine fault warning light on as soon as the cycle is 3000, but it goes out on its own after a few days. Even if the cycle is 4000 while going, the fault light does not come on, these situations started to confuse me, the egr valve comes to my mind but in this case black smoke throws, mine is throwing blue smoke, maybe oil may leak from the valve tires because the smoke is blue but there is no oil shortage, no problem in injectors Even if it was cold, it works and there is no misfire in the engine, it is a very complicated and contradictory situation, what should I do, I will go to Ankara for a month or two, there is a good peugeot service, if I connect the engine to the computer without much tampering, there is a peugeot service in the mainland you can recommend, thanks, best regards ...
08.05.2020 20:06 # 2
erhan teacher, it is difficult to find a good master. if you say authorized service, fatih peugeot special unfortunately my master fordcu i know but i go to him i always took all my vehicles to him peugeot - megan- auris - focus
throwing blue smoke
The turbocharged oil outlet pipe is clogged because the turbocharger in the turbocharger may not have an excessive outlet in the turbocharger.
It is an excerpt.
08.05.2020 20:06 # 3
407 ERHAN
Sonerkyl friend, thank you very much, you are right, what you say is very reasonable, what you say may be but it burns fuel very abnormally, I am even ashamed to say, it finds almost 50 cents in the city, it is very very abnormal situation for a diesel car, as if it is a gasoline car, why may it be?
08.05.2020 20:06 # 4
erhan abicim fuel consumption is related to injectors, let me tell you about it unfortunately, you have no chance other than having the injectors checked. I have 407 1.6 hdi in my neighbor, he did not complain about the fuel, there is 900 km in the city. 50 krş is really going to be changing about more or more valve tires. I think it will cost around 1500-2000 TL depending on the situation, the repair of the injectors is between 900-1200 TL.
08.05.2020 20:06 # 5
407 ERHAN
I understand, however, I always buy shell v power nitro for fuel, never get fuel from other places and different fuel, I'm very sensitive about it, I don't understand why this happened, thank you again, my friend.
08.05.2020 20:06 # 6
407 ERHAN
I wonder if fuel additives can disrupt injectors, once I put powerup, würth at once, fuel consumption after that has increased a lot.
08.05.2020 20:06 # 7
erhan brother, this is not about you. There are many factors. They highly recommend the pump in Ankara. Of course, there are other places to recommend to friends.
08.05.2020 20:06 # 8
407 ERHAN
So the previous mistakes came and found me, my sonerkyl brother, when I bought the car, the fuel was very low, it has increased a lot for the last 6 months, now I calculate it, it is 160 km with 75 pounds of diesel in the city, which is between 45 and 50 cents, but normally 30 cents in the city. my vehicle would not pass ...
08.05.2020 20:06 # 9
good brother, as I said, good master turbo hoses etc. it will check well. they will look at the intercoler situation. I would recommend it if my master was a peugeot zhou. I could even go together, I would help the weekend.
08.05.2020 20:06 # 10
407 ERHAN
Thank you very much, sonerkyl brother, when it helps you, enough, I wish kib, well-being, good day 😉
08.05.2020 20:06 # 11
You're welcome, brother, what do you mean? You are entrusted to kib allaha. If your way down, let me know, don't go without a tea. Smile
08.05.2020 20:06 # 12
407 ERHAN
In May, in May, when the weather gets warmer, I will go on annual leave, there is a father-in-law on the mainland, I will stay for a week or so, I will see you later, brother, wish good luck, stay healthy 👍
08.05.2020 20:06 # 13
thank you brother Thumbs Up stay with you.
08.05.2020 20:06 # 14
407 ERHAN
Hello friends again, thank goodness the smoke problem in my vehicle has also disappeared, the master said that the injectors need to be revised, it can be fixed with repair without replacing it with a new one, and the repair kits of the injectors in the pump have changed, that is, the consumable parts have changed and kept a total of 1100 TL including labor, the injectors zero On average, around 600 TL, I almost eliminated my half price breakdown, there was not that heavy smoke left in the first start of my vehicle, the traction increased, it was more comfortable on the road and the fuel consumption was falling rapidly, burning 8.6 liters of diesel in the city before the repair last week, to press the gas I was afraid, I even saw 9 liters sometime, I couldn't take my eyes off the fuel gauge, but after the repair, I made an average of 100 km and the fuel consumption is decreasing rapidly, now it is 8.2 lt, my goal is 7.5 lt isine for the knowledge of friends with similar problems, good day ...
08.05.2020 20:06 # 15
I am glad that this problem has been resolved. Smile
08.05.2020 20:06 # 16
407 ERHAN
Thank you, Sonerim, thank you, I hope all my friends who have malfunctioned will fix their problems, hope to see you again, brother, stay with health, have a nice day ... 😉
