My 307 vehicle is self-accelerating ???
08.05.2020 17:03 # 1
emntstn
My car with the 2003 model 307 tiptronic tartarini system has been hung up in the last days.When running in the morning, the gas stops & nbsp; stops when the engine is cold. I get up, I press the brake, but I bridle it, it puts itself forward as I stepped on the gas for 2-3 seconds from the moment I applied the brake. The throat butterfly was cleaned, the calibration was done. Can you give?
08.05.2020 17:03 # 2
muro_60
If you have a problem with the gasoline injector, it will hurt if you want it.
08.05.2020 17:03 # 3
ekinoks44
I encounter the same problem once in a while. Sometimes it stops when I press the gas at the first run. And sometimes when I stop at the lights or park the car & nbsp; & nbsp; He wants to go to himself, he wants to go, I hardly get an obstacle :) I don't know what the problem is. We are managing for now, you will understand.
08.05.2020 17:03 # 4
kaan__
Have a good master perform a LPG calibration ...
08.05.2020 17:03 # 5
emntstn
The problem does not happen when the vehicle is in LPG, it is in gas. This problem is not in LPG. There is no problem in the vehicle ....
08.05.2020 17:03 # 6
kaan__
try to clean the throat throttle ... if the problem is not solved, have the coil checked ... finally have a check on your spark plugs
these are the things I can think of for now
08.05.2020 17:03 # 7
emntstn
throat butterfly cleared, spark plugs changed ... the problem continues ...
08.05.2020 17:03 # 8
emntstn
I'm looking for someone to help with this.
08.05.2020 17:03 # 9
emntstn
08.05.2020 17:03 # 10
emntstn
08.05.2020 17:03 # 11
salihata
I write here so that the issue is not polluted, I have the same problem. Is the problem solved ?
08.05.2020 17:03 # 12
xMEGANx
It's very strange. I have 2007 HDI Diesel, the computer automatically cuts the gas when pressed on the gas and the brake at the same time :) The vehicle goes to the press gas as much as you want, but it does not eat the gas, then it automatically recovers. but I guess you are not connected to the gas brain wired I guess
08.05.2020 17:03 # 13
[QUOTE = xMEGANx] is very strange. I have 2007 HDI Diesel, the computer automatically cuts the gas when pressed on the gas and the brake at the same time :) The vehicle goes to the press gas as much as you want, but it does not eat the gas, then it automatically recovers. but I guess you are not connected to the gas brain wired I guess [/ QUOTE]
This is a feature.
08.05.2020 17:03 # 14
emin15
There is a problem in the engine brain, it cannot control the injectors.
08.05.2020 17:03 # 15
Ayalcin42
THERE IS A PIECE LIKE A PLUG ON THE OXYGEN POST-TOP EXHAUST MANIFOLD IT IS DEFECTIVE REPLACE IT IS OK.
