My 307 problems
08.05.2020 14:53 # 1
Good evening. 2002 model I have 307 xt. I have a few problems.
1) My vehicle with a landi renzo tube is used to consume gas while driving with LPG. In addition to the fact that it uses the gas during the first operation and it can make a decrease because of this, I clearly saw the indicator disappear when I turned off the ignition.
2) When my car travels 200 250km without stopping nearly, when I first stop or slow down to stop and move to idle. In the middle of the night, it is getting normal after the third gear.
3) occasionally I smell the gas in the car. While I am already suffering from the decrease of the gas while using lpg.
I appreciate if you can help. Thanks in advance.
08.05.2020 14:53 # 2
nteker
1. Your problem is quite normal, because the gas gauge drops according to the rotation of the wheels, and in our 307 vehicles, the gas gauge drops even when driving at lpg, since the gas gauge is connected to the brain. Take a 20 TL gasoline instead of the original, but it starts to drop again. You will see the gasoline in your vehicle during these 20 TL gasoline purchases.
I suggest you consult a master for your 2nd and 3rd questions, I have landi, but I have not experienced these problems.
08.05.2020 14:53 # 3
evren307
If the vehicle has LPG, do not believe the trip computer's gas gauge.
08.05.2020 14:53 # 4
BAHTIYAR
it does not consume gasoline, but the indicator shows missing because it is connected to the wheels, not less than half a tank / if the tank is full of half a tank, if you put the vehicle on a slope, it will recover or you can put 50 pounds of gas once a month as I do.
2) If the vehicle is automatic or manual, I will say press pad but it happens occasionally, I have no idea
3) Raise the right rear seat, there is a place with a black cover, where the gas pump is, take a good look at it, but do not tamper with it may leak
08.05.2020 14:53 # 5
Thank you for your ideas, friends, for problem number 2, can the cause of the transmission oil be broken or decreased? This weekend I could not get to the master, but I said by phone, let's take a look at the problem. Why would this be? In the meantime, let me add the presentations related to this problem.
08.05.2020 14:53 # 6
Selim Engin EREN
Are these 307s never finished with the problem ...
08.05.2020 14:53 # 7
[QUOTE = dereli34] these 307's never ending problem ... [/ QUOTE]
If it breaks out, it will not end.
The problem is not in the car.
08.05.2020 14:53 # 8
Fahri
Friends bought the 2005 model Gasoline 1.6 engine 110 horsepower xt automatic gear peugot 307. I am waiting for your comments
08.05.2020 14:53 # 9
ayter
[QUOTE = ultrAs] good evening.2002 model I have 307 xt. I have a few problems, I would be very happy if there are friends who can help.
[/ QUOTE] like the display shows the lpg with the lpg connected to the wheel, but there was the same problem with the lpg. If you hold down the lock button on the doors above the key for 20 seconds, the vehicle will reset the brain and the indicator will re-calculate the gas in the tank (after 20_25 seconds, then the signals start to flash, but it is understood that the process would take place at the second but it was not at the first half but it was similar to the second.
08.05.2020 14:53 # 10
diabolicfb
There is quite a suggestion for the 1st mara that a chronic LPG Peugeot mismatch can be called. I read something called PSA module for this needle to work properly.
For the number 2, I experienced a similar situation like this, although the vehicle ate up to 5000 revolutions on a straight road, it did not work. They changed the ignition coil system in me.
For the 3, there is a petrol engine pump under the rear right seat. Check the plastic hose at the motor outlet here, it may have cracked. Get well now, the 307s are already a bit of a problem, but if someone like me pimpy is getting used to it, you will probably see what I mean :)))))
08.05.2020 14:53 # 11
okan77
Either these are things that can happen in every car .... they have less problem than Alfaromeo :)
08.05.2020 14:53 # 12
ismail ozdemir
As far as I know, there is no samandra in the 307 gas tank, the road computer is falling and the gas is falling according to the mileage it makes.
08.05.2020 14:53 # 13
qaan
how do you know when your brother turns the key without pressing the starter then? Ermm
08.05.2020 14:53 # 14
ceronimo1978
My friend, the solution to the 3rd problem, there is a part called o-ring between the certain buoy and the fuel tank. You need to change it for 20 TL.
Respects.
08.05.2020 14:53 # 15
ertan ozcan
friends The lamp C, which measures the outside air temperature on the instrument panel, has been constantly flashing since my 2003 model 307 XT 1.6 automatic gearbox. what would be the reason?
08.05.2020 14:53 # 16
sercinho
[QUOTE = ertan özcan] friends The lamp C, which measures the outside air temperature on the instrument panel, has been constantly flashing since my 2003 model 307 XT 1.6 automatic gearbox. what could be the reason? [/ QUOTE]
If the air temperature outside was burning at 3 degrees and below, I know that it should not be burned above 3 degrees.
08.05.2020 14:53 # 17
drburak2525
My friend, I had a "teleflex" brand LPG at the Peugeot Göral Ankara authorized service about 1 month ago. They installed a module called PSI or PSA alongside the LPG montage. The feature of the device is to reset the petrol indicator when the km lights go out after stopping the car; that is, the next time you start the car it shows how much gas is in the gas tank. The progressive gas gauge on the road acts as if gasoline is falling; however, the tool. It consumes LPG, not gasoline. If this module is available, when you turn the vehicle off and on, the indicator shows the current gasoline.
Also, the vehicle is automatic, there is a problem in 1st and 2nd gear; You wrote that you did not switch from D to M. I had the same problem. Especially when climbing uphill, it gives "automatic great fault" warning and fixes it in 2nd gear. It does not exceed 50 etc. etc. I found that 307s have a chronic problem with AL4 transmissions, both from my incident and in my research. You will go to the peugeot service. There are 2 solenoid valves regulating hydraulic pressure, they and transmission oil will change and the problem will be eliminated. When it comes to the smell of gasoline, I recommend you to go to the master and have the gas pump checked.
