My 307 problems
08.05.2020 14:52 # 1
muhtesem
Hello, I just joined you ........
I bought pevgeot 307 2003 model 17700 thousand 5 days ago from the gallery .... anyway I will not stretch it much
From the very first day, the malfunction lamp was lit, the repairman said that the accelerator pedal sensor was broken, and the vehicle does not see the accelerator pedal at the first start or occasionally it is running at idle.
then I bought a 70-pound lpg 300 km didn't even go .. do these cars burn a lot?
and the fever is over
I have cooled down a lot from the car already and it is the model that makes the land very chronically ...
I wonder if my brain is broken or what?
Give reason for God's sake, comment, I gave money to a world !!
let's 2010-08-23 19:08:20
08.05.2020 14:52 # 2
EminONAL
Good luck first.
Didn't you show it to any master to make sure there was any malfunction while you were buying your vehicle? when buying from a place where it is not possible to approach biasedly like the heleki galleries?
08.05.2020 14:52 # 3
How many km in arc? Once you get the lpg fitted head-on vehicle. You have eaten the first bread and sold it in such a way. Did you show the master that my friend said or were you tricked by the gallery's very clean car?
08.05.2020 14:52 # 4
muhtesem
unfortunately we bought it without showing it to any master (trusting the dealer) ....
103 thousand km to the vehicle
08.05.2020 14:52 # 5
Well, if the master told you there is a water problem, this problem is 5 thousand TL, would you buy it? or let's take this amps if you said take it like that
08.05.2020 14:52 # 6
fatih1903
hello;
Brother, you pay a little bit for every vehicle you buy second hand.
If the duration of the LPG is long, I would like to do some maintenance.
307 burns a lot is not clear from the 60 liter gas tank already :)
If the vehicle's brain is broken, it gives a lot of errors and does not even walk.
If 307 is a very delicate vehicle, it is normal for you to bring these problems to you ...
but if you want you can sell it for the money you get :)
08.05.2020 14:52 # 7
EminONAL
It has been five days ago, the malfunction was in the foreground, it is highly probable that if I were, I wouldn't bother personally, I'll go to the head of the man I bought, throw the keys, I get my money. I will show it to the master if I will get it from my father's son!
08.05.2020 14:52 # 8
muhlisoz
Firstly, get well soon. I bought the car first, I showed it to the service the next day, there were a few other problems different from what the owner said, but thank God, there was no serious expense.
The vehicle burns a little too much and its temperature is generally high. Get well again, if you can, take the car back and get your money back
08.05.2020 14:52 # 9
muhtesem
Thank you very much to the friends who answered the vehicle 2003 model
It has been 3 years with lpg pacemaker ....
08.05.2020 14:52 # 10
[QUOTE = EmRaH] at how many km of arc? Once you get the lpg fitted head-on vehicle . You have eaten the first bread and sold it in such a way. Did you show the master that my friend said, or did you say that the galler doesn't have a lot of clean cars [/ QUOTE]
Why is that_???
08.05.2020 14:52 # 11
evren307
I disagree with the interpretation that LPG is stuck and gone, I don't want to be too pessimistic, I think a little bit of the vehicle should burn around 70 pounds for around 500 km.
08.05.2020 14:52 # 12
bayelektronik
307 is primarily good. Some friends say it is not certain that the tank is 60 lt. It is wrong to say that 307 is very burned. While buying, I had a 307 lpg with a lower price, I did not prefer it. I heard it was very problematic. The same thing comes in. Bid you would have broken the original of the car. As a 4-month user of 307, I am very pleased with my car. The heat of the .307 city It rises in use, but the part up to the red in the needle is normal. If the red dot and above are problematic.
08.05.2020 14:52 # 13
bayelektronik
In the meantime, 300 km long city or out of town
08.05.2020 14:52 # 14
muhtesem
intercity / out of town mixed ....
08.05.2020 14:52 # 15
H-a-d-i
Unfortunately [QUOTE = awesome] we got it without showing it to any master (trusting the dealer) ....
you made the first mistake from the beginning. If my father was a galler, I wouldn't trust him either. that is the degree.
Since you did not introduce ourselves, the first rule of the site, I could not determine which city you are in. 307 is indeed the ideal vehicle in its class according to its price and equipment. If it is not applied hard, domestic fuel oil will not exceed 32-33 Krş. LPG doesn't really taste in 307, or known brands like BRC, Zavolli should be preferred. I think Emrah wanted to say that.
I think what you have to do now is to find an honest and competent master, and you must have your fault determined by not precisely trial and error.
08.05.2020 14:52 # 16
bayelektronik
[QUOTE = Come on] [QUOTE = awesome] unfortunately we bought it without showing it to any master (trusting the dealer) ....
I think what you have to do now is to find an honest and competent master, and you must have your fault determined by not precisely trial and error. [/ QUOTE]
Exactly, my teacher, the son of my very close older brother, sold me the toyota that was somersault in time.
By the way, there are 300 km of inner and outer mixed roads. There are 307 in me. I make these miles with gasoline.
08.05.2020 14:52 # 17
kuhi
Hi guys, I love 307le,
Birtane 307 I found it very clean, says the gallery :)
But gasoline LPG does not seem to be fully compatible with these 307s!
If I wear LPG, I would be glad if anyone who knows I am in Ankara is the most compatible one, if anyone throws the best LPG in Ankara to these pegoes,
Is there a huge profit between LPG and gasoline, or can I make a profit if I use LPG for a car that I will use for 2-3 years, for an average of 20-25 thousand km per year?
I am waiting for the answers of experienced users,
08.05.2020 14:52 # 18
ceronimo1978
Sir, this week I am getting Zavolli mrka Lpg, in Beylikdüzün. After long researches, I decided on Zavolli. By the way, it could be in BRC. Other models clearly write that it is problematic forums
08.05.2020 14:52 # 19
kuhi
Sir, what is the km burning in gasoline? What will you do when you predict LPG?
