My 307 car vibrates at 130
08.05.2020 18:42 # 1
Akdenizli82
friends, I went a long way a week ago, I am very happy with my car, but I noticed something .. the car starts shaking when it comes to 130 What do you think is the reason ... they say rorot but I don't understand much
08.05.2020 18:42 # 2
albayman
Possibilities:
1.) skew on the rims. (rim enters the correction process)
2.) trouble with wire breakage etc. (tire changes as right left pair)
3.) balance imbalance (must enter balance setting)
08.05.2020 18:42 # 3
TaZ
If you go to a rot balancer, I am sure that your problem will disappear :) The friend who wrote it above can not be for any other reason that tremor.
08.05.2020 18:42 # 4
madblueblacksea
If there is a gap in the axles, it again makes high speed tremors. I recommend you have the ground balance on the tires in fine tuning
08.05.2020 18:42 # 5
Akdenizli82
Thanks for your attention. How much does this Rot balance cost me?
08.05.2020 18:42 # 6
albayman
If the balance is broken the balance is simple, they will get a maximum of 20-30 TL. but if the tire is going to change, it will negotiate the price of the tire you will buy.
if the rim is crooked, it goes to the rim rectifier, if it is not broken, it will be straight, 20-30 per rim, I do not know the latest prices.
First go to a balancer and let the vehicle look at the balance settings without removing the tires. whether it is already rimmed or bad, it looks bad. Is there rhythmic sound with balance when going on flat asphalt?
08.05.2020 18:42 # 7
Akdenizli82
Colonelman sorry, my friend, I was on vacation, I could not write an answer ... there is no sound, only tremor is happening .. I called a familiar master, he said it might be from the brake disc.
08.05.2020 18:42 # 8
Akdenizli82
friends, the problem was in balance .. today they removed the front wheels and adjusted the balance, shudder gone .. the cost is 20 tl
