My 306 car doesn't eat gas? Help..
08.05.2020 16:39 # 1
ozkan
Friends. & Nbsp; I just bought the car. Clutch set changed 3 weeks ago. I don't know the car. However, the performance of the vehicle was very good, even though the clutch & nbsp; was problematic. After the clutch, the vehicle does not eat gas. Especially in the first three gears and around 2000 revolutions, the vehicle is softening, it does not eat gas. & Nbsp; No problem after 3000 passes. I don't want to bring 98 model vehicles to the authorized service. Every master said something else. Spark plug, spark plug cable, ignition coil, pressure sensor, crank speed sensor, tube is defective, there is dirt. The butterfly throat is the runway. It has been said that it has electrical failure. I was surprised what to do. Let's come to what I did. Butterfly throat cleared. The spark plugs and cables have changed. The ignition coil has been attempted. The tube was maintained. It has been reprogrammed. It was said that there was no problem & nbsp;. I connected the vehicle to the computer and they said that there was no problem. Now they will replace the pressure sensor, crank speed sensor and ignition coil. However, I suspect that I will find a solution to the problem when I change it. I don't want to waste money. Has anyone encountered this situation and found a solution? Emergency aid. & Nbsp;
08.05.2020 16:39 # 2
istanbullu_3886
look at the air flow meter
08.05.2020 16:39 # 3
istanbullu_3886
and if the vehicle is diesel, look at the turbo pressure valve & nbsp;
08.05.2020 16:39 # 4
ozkan
Vehicle 1.6 8V Lpg, li
08.05.2020 16:39 # 5
ozkan
The problem is still not resolved. However, 2 master speed sensors are broken. I can't find the speed sensor. Emergency aid.
08.05.2020 16:39 # 6
estair
It would be useful to look at the gas wire. I had a problem like 106 das. What is the circumference of the wire? What car does not eat gas?
