My 206 XR 1.4 car is thinking to buy 17 inch wheels
08.05.2020 17:34 # 1
poyrazefe
I am thinking of buying a 206 XR 1.4 car 17 inch rim.
08.05.2020 17:34 # 2
_PunisheR_
Depending on the rim weight but how light it is, your 17 inch car 1.4 I think 15 inch is ideal, other friends share their ideas.
08.05.2020 17:34 # 3
Bugra
There is a real teacher, the overall tire dimensions of the 206 vehicles of 206 are 175/65/14 type, ie 14 rims. but since the RC is a 2.0 engine, the original rim size is 205/40/17 as far as I can remember.
The traction of the vehicle may drop. Of course, not only the rim, but also the floor width on the ground is important.
08.05.2020 17:34 # 4
poyrazefe
bases backs 45 prevents 40s the comfort I was wondering, would there be a decrease in comfort?
08.05.2020 17:34 # 5
outlaw
I think no 17 '' contamination is always the word the tires say, 1 is bigger than the standard tire of the car.
I had 15 '' wheels, I dropped 14 '' for the health of my car ...
08.05.2020 17:34 # 6
Bugra
[QUOTE = poyrazefe] soles backs 45 avoids 40 I am wondering if there is a decrease in the comfort I was wondering, I did not know that the person I bought has not used any suspensions without playing 206, I do not know. [/ QUOTE]
No 45 or 40 base width! they are the height of the cheek. and all dimensions must be the same on all 4 tires. 175,185,195,205 etc. base width like they are ..
If the height of the cheek is low in terms of comfort, your comfort decreases.
08.05.2020 17:34 # 7
samet206
drops from traction, fuel increases, front set, unnecessary tiredness, comfort decreases, I saw 17 wearing 1.4 XR, I use the same model as myself, but I do not get out of 5CM springs and 15 rims.
08.05.2020 17:34 # 8
Sendman
We have the same vehicle ..
I have 16 in my car, I'm not happy at all.
I'll get 15 as soon as possible ..
08.05.2020 17:34 # 9
rolandgarros
[QUOTE = Sendman] We have the same vehicle ..
you are not satisfied with the generation, teacher? fuel consumption, road holding etc.? I would appreciate if you specify I think I would raise inches, I can give up accordingly Smile
08.05.2020 17:34 # 10
KenBlockJR
Get 195-55-15 tires and 15 '' original wheels best
08.05.2020 17:34 # 11
Sendman
First of all, since the front wheels are out of the vehicle, even if you have just washed your car, a slight mud is throwing all the mud to the side.
Even if there is not much fuel consumption, there is a slight increase.
For some reason, I could not cut the front team sound, I put these wheels on.
08.05.2020 17:34 # 12
MagicPerformance
[QUOTE = Sendman] First of all, because the front wheels are sticking out of the vehicle, even if you have just washed your vehicle, a mud is throwing all the mud to the side.
the overflow of the tires is not due to the diameter, but because you use a rim without a peugeot ET.
08.05.2020 17:34 # 13
SDYMZ
performance increases as the cheek thinks comfort decreases
The performance decreases and comfort increases as long as the cheek is not left. that is, an inverse proportion with each other you will understand. I have RC original 17 inch 9.5 kg original 14 inch rim heavier. I use it in places like Izmir, I use the patch very carefully on the roads. I can easily go 950 km with a warehouse. Let me tell you, if it takes 15 inches and is over 10 kg, what does it mean?
08.05.2020 17:34 # 14
Anil Ercan
Install 195 50 15 and 15 rims to the vehicle or install the worst 205 40 16. 17 Do not buy rims. The original size of my vehicle was 205 55 16, now with 17 wheels and 225 45 17 tires attached, there is no comfort left in the car.
08.05.2020 17:34 # 15
asi_black
Hodja, I have 1.4 xr on me, I have 16 wheels on it. 195.45.16 now I count you negative sides, because the cheek is thin, when all the weight enters the first hard pit on the cheek, you eat the cheek, this is buying another tire. your car will be like a stork, it will affect the fuel, traction will drop, you will get the front team if you are going to get the orgy 15 inch 5-spoke peugeot rims, I regret it, the only good thing was, think well, hodja
08.05.2020 17:34 # 16
Barut
My car had original 14 cans, now 17 original rc wheels are installed, I have not seen any difference, of course, it is important that the wheels are original.
08.05.2020 17:34 # 17
mistik
If you wear 17 rims on 206, you need to wear a thin sidewall tire, 45 and so on ... your grip increases, the brake decreases, but you feel a little stone on the road, and the movement starts moving under your hand :) softness in the steering decreases. can rub ..
08.05.2020 17:34 # 18
otosundur
The most beautiful 195 45 16 original rc wheel tire. Mine is perfect
08.05.2020 17:34 # 19
allppeerr
If you think of 17 '' rc wheels, give your owner 15 '' rc wheels similar to your car.
08.05.2020 17:34 # 20
otosundur
cc rim remains very small, master
Page : / 2
