My 206 vehicles dropped from traction
08.05.2020 17:29 # 1
ufukdenk
Hello friends
206 Xr 1.4 2000 My gasoline vehicle was not fitted with any LPG recently. When I was on the ramp with 2 or 3 people recently, the traction of the vehicle decreases a lot and I have to downshift. I take the gear to 3 when it comes to the cycle, but since I can't collect the car, I have to take it to 2 or 1 again. When I continue with 1 or 2, the temperature rises and the vehicle goes hard as if pulling a vehicle from behind I showed it to the master in the industry. He said, but there was no such problem before, there is no problem on the straight road and on departures.
08.05.2020 17:29 # 2
ilyas
The first thing that comes to my mind is the pressure pad and the second one is the catalytic converter. but the pressure is more likely to be lining. I think it's the power of this car.
08.05.2020 17:29 # 3
ufukdenk
Thanks for your comment, I thought that the pressure pad was a bit more fuel in my car, but the master pulled the handbrake and tested it will take you more.
08.05.2020 17:29 # 4
qqyyxx
checking the vehicle's air filter, etc. extra air intake affects fuel and traction
08.05.2020 17:29 # 5
ufukdenk
I changed the filter and spark plugs of the vehicle about 6-7 months ago.
08.05.2020 17:29 # 6
samet206
If you think that the pressure pad is the air filter, the belt will cause the knife even more.
