My 206+ vehicles are on the way
08.05.2020 20:08 # 1
umitgun
Hello friends
2012 206+ 1.4 gas + LPG user
While I was on the road today, I looked at the car, it was throwing white smoke, I pulled it to the corner. At the same time, there was white smoke and idling. I did not want to go over the water, I parked the vehicle where I came, I came to the house could have burned gaskets Do you have any car information?
08.05.2020 20:08 # 2
samet206
First of all, it is like a complex situation. It seems like a complicated situation. I am putting water on it. You are saying it is missing. If the cause of water is missing, this is a different issue. But because the leakage is irregular due to the leakage, the car burned waterless mold gasket. It is hard to say a few things without doing a few classic tests and opening the vehicle. If all the reactions of the vehicle are in this direction only then the engine turns on. Look at the oil status from the simplest, look at the spare water can.
samet206 2017-01-23 01:30:22
08.05.2020 20:08 # 3
My teacher first of all is exactly where the water is leaking from the bottom of the reserve water tank, or from the thermostat body or radiator. as our friend said, it might have burned the gasket. There is usually a free tow truck service in our fuses, which will inform you if you call your fitter.
08.05.2020 20:08 # 4
umitgun
I do not understand the engine so well, but I looked at the car's normal water tank hoses, it does not escape from the bidet, the other side of the job is that water is gone, the temperature indicator in the car was at its normal level
08.05.2020 20:08 # 5
umitgun
I talked to the service, I explained the condition of the vehicle, the gasket fln burned, they said it costs 3-5 thousand liras.
08.05.2020 20:08 # 6
ggitaristt
I think you have overheated you did not notice the gasket burned. Then, adding some water, the temperature returned to normal.
If only the gasket is burned, if you make it in a private service, 1500 amount is the most. I don't think it will cost 3-5 thousand.
08.05.2020 20:08 # 7
x571
[QUOTE = sonerkyl] My teacher is getting exactly where the water is leaking first, it is better if you detect it from under the reserve water tank or from the thermostat body or radiator. as our friend said, it might have burned the gasket. There is usually a free tow truck service in our fuses, and it will inform you if you call your fitter. [/ QUOTE]
Is it a car insurance free tow truck or compulsory traffic insurance? Now, if this friend wants zero engine from peugeot service, how many thousand TL is given? Do you have any information, albeit average?
08.05.2020 20:08 # 8
umitgun
[QUOTE = ggitaristt] I think you overheated, you burned the gasket, you didn't notice. Then, adding some water, the temperature returned to normal.
I was someone who was very careful about the water in the car's oil. I had a bit lacking the water a day ago. I was at the normal level when I got white smoke. I took it to my own master. We looked at the gasket, it keeps a burnt figure like 1.000 TL.
08.05.2020 20:08 # 9
ggitaristt
so gasket is 50 lira.
If you have frozen water in the engine, you may have burned it too .. If the circulation thermostat or something is broken, be prepared for them ..
08.05.2020 20:08 # 10
umitgun
[QUOTE = ggitaristt] so the gasket is 50 lira.
As you said, the closed box can come at other costs. I hope it doesn't cost more 2012 cars, but I don't leave the industry. I put the salary in the car.
08.05.2020 20:08 # 11
Eyup B.
I have 206+ diesel 2010 model, but thank god I did not have such problems.
The only thing I complain about is that the front teams break down quickly and the rooms are known as Istanbul roads :)
First of all, I highly recommend you to go to a good master, get well soon. We are a nation that attracts 3 thousand people who are on the road.
08.05.2020 20:08 # 12
[QUOTE = umitgun] I talked to the service, I explained the condition of the vehicle, the gasket fln burned, they said it costs 3-5 thousand liras. [/ QUOTE]
Maşallah, the master will fly 3-5 thousand what, or what will make a complete engine, the cylinder head gasket replacement is enough, my teacher room mehmet, as our friend says, keeps a maximum of 1000-1500 TL. get workmanship 400 tl engine grinding 150-250 tl gasket set if you buy 150 tl timing circulation set if the original 250 tl engine oil 75 tl filters will mean an average of 15 tl, we will estimate about 1200 tl
08.05.2020 20:08 # 13
x571
[QUOTE = sonerkyl] [QUOTE = umitgun] I talked to the service, I explained the condition of the vehicle, gasket fln burned, they said it costs 3-5 thousand liras. [/ QUOTE]
If this friend provides zero engine from peugeot service, how much price is asked for the environment.
08.05.2020 20:08 # 14
at least 2-3 TL more than the market in the service. The vehicle between 1000-1500 TL has to enter the inspection one by one. you need to research well, get the price, we think it is the crate engine. I think that even if the finances are out to you under the most favorable conditions, it will not be below 8000 TL even in private.
08.05.2020 20:08 # 15
x571
[QUOTE = sonerkyl] at least 2-3 tl more than the market in the service. The vehicle between 1000-1500 TL has to enter the inspection one by one. you need to research well, get the price, we think it is the crate engine. In the most favorable conditions, I think that even if his finances are out, he will not be under 8000 TL even in private. [/ QUOTE]
I wish it was only cheap with only 5 thousand. We invest the money after 5 thousand into the government or something. Is not 1500 too many for operating the license or the undercoat will change the chassis no. Starting from 5 thousand is the smallest engine, I wonder 1.6 what is the price of an engine? When the engine I see around me gives a malfunction, it costs 4,000 TL in parts for repair, which makes people harass people.
08.05.2020 20:08 # 16
I am holy, the cylinder head gasket was gone, it was 40 thousand km. Thank God I did not have any trouble, the craftsmanship of the master, I reached a figure of 1000 TL. You are taking out a project from the engineers' room for the engine, the teacher was about 600-700 TL, the cost of which was afterwards, the final inspection license etc. It exceeds 1000 TL
08.05.2020 20:08 # 17
umitgun
I thank you all for your help.
1 . If I supply the parts myself, can I reduce the cost.
2. What are the parts that need to be replaced?
All the 3rd parts must be original.
the umitg 2017-01-24 15:18:44
08.05.2020 20:08 # 18
you are welcome hodja
If you can get the pieces, it will be a little more convenient. Of course, some masters can say that I will not interfere if the problem occurs, and can charge a fee for repetition. This is a situation between you and the master. It would be better if you pay attention to its original durability in terms of longevity.
08.05.2020 20:08 # 19
sporcu
Get well soon. I also have 206+. It is nearing its 5th year. The best I have ever used (including hawk like roses). I started to be annoyed with the French of Peugeot.
08.05.2020 20:08 # 20
x571
[QUOTE = athlete] Get well soon. I also have 206+. It is nearing its 5th year. The best I have ever used (including hawk like roses). I started to be annoyed with the French of Peugeot.
I have been using Peugeot for a year, but a lot of users think like you. I wonder why.
Page : / 2
