My 206 dial gets stuck. !! please help ..
08.05.2020 18:54 # 1
canmehmetsen
Hello friends
vehicle model: 1.6 xs 99 model
recently the speedometer gets stuck
For example, when I go with 50, it hangs down from 50 even though I don't get down .. However, even if I go with 20, it shows that it is 70 even when it is 50.
I turn off the contact and pit 5-10 times every turn, the AC drops 10 km km and comes to 0.
2 reasons why I think ..
The dial of the 1st dial may have failed
I had the 2nd controlled exhaust, the electrician connected the exhaust to the display panel of the instrument panel, this problem occurred after the exhaust was connected, the electrician installed the 5 ampere dashboard when I noticed the exhaust, I put it back in the 10 ampere booth.
possibly the circuits on the instrument panel were damaged due to excessive current.
If there are other friends who have experienced this problem and who has knowledge, can they share it?
You can reach the photo from the address below.
http://hizliresim.com/a0q3kv
08.05.2020 18:54 # 2
samet206
Indicator problems always appear in 206. I find it abnormal to see that it does not come anymore.If it turns out, it sounds normal.
