My 206 cars are not towing
08.05.2020 17:07 # 1
cnrars
Friends, I have a 2006 model 206 1.4 X-Design vehicle, 2-3 people in it, which weighs 50-55 kg, my vehicle has very poor traction, I need to downshift constantly, no problem on departures, why?
08.05.2020 17:07 # 2
shadoww2
You don't use cycles, it's a diesel car.
08.05.2020 17:07 # 3
cnrars
You don't use [QUOTE = shadoww2] cycle, it's a diesel car.
Thank you for your answer. & nbsp; I use cycles, it's okay, but I need to downshift on the slightest slope, I know I continue with 1 where I can go with 3.
08.05.2020 17:07 # 4
shadoww2
So is there a misfire.
08.05.2020 17:07 # 5
cnrars
[QUOTE = shadoww2] OK, is there a misfire. Coming, pushing, shouting, shifting gears, when I change it, I can't get it together, I get 1 again,
This is happening when I go uphill with 60-70, After a while, I press the gas to the end and I have to downshift.
Meanwhile, I can go 180-190 km with 50 pounds of diesel.
08.05.2020 17:07 # 6
muro_60
check the turbo hoses, it can be torn or something & nbsp;
08.05.2020 17:07 # 7
cnrars
[QUOTE = muro_60] check turbo hoses can be torn or something & nbsp; [/ QUOTE]
It comes to my mind about something related to turbo, and when I press the gas up to 4000 when the car stops, I think it is viffffff With an ongoing sound engine, his voice decreases and becomes silent, what could it be?
08.05.2020 17:07 # 8
volkan206+
I had the same problem, I went to the service, the turbo hose was getting loose from the air, it was due to it,
They fixed it, no problem anymore
08.05.2020 17:07 # 9
muro_60
[QUOTE = cnrars] [QUOTE = muro_60] check the turbo hoses can be torn or something & nbsp; [/ QUOTE]
I think of the thing about turbo, while the car stops, up to 4000 When I press and release a sound that goes on as a vfffff, the sound decreases and decreases with the engine, what could it be?
[/ QUOTE] & nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; & Nbsp; The turbo is already running, the sound does not give air, look at the hose
