My 206 car goes back when it turns
08.05.2020 18:06 # 1
koray
my friends, i have a 2001 model 206 xt vehicle, when i go to the bend, it can be caused by traveling around the back.
RESPECTS
08.05.2020 18:06 # 2
acypower
A situation caused by torsion.
08.05.2020 18:06 # 3
remedy 106 Tongue
08.05.2020 18:06 # 4
C@GL@R
In 206, the normal bits go back in the smallest bend: D I like it, knowing, I do it on purpose.
08.05.2020 18:06 # 5
akantek
I just changed the rear tires for this. Now someone from the back is sticking on the road.
08.05.2020 18:06 # 6
outlaw
[QUOTE = koray] friends I have a 2001 model 206 xt vehicle, when I go to the bend, it can be caused by traveling around the back.
RESPECTS
LOOK AT THE REAR BALANCE BAR ...
DOES NOT MAKE FROM THE TORSION ...
08.05.2020 18:06 # 7
KILIC
Hodja could be tires. If the tires are bad, worn, there is not enough air, it can slide. It can also be from the brake. It may also be made of shock absorbers, if one of the shock absorbers is broken, it cannot touch the ground sufficiently. You should have them checked.
08.05.2020 18:06 # 8
koray
Something caught my attention wherever you call the balance bar, there is always a creaking noise as it goes, it seems like a rusting piece.
08.05.2020 18:06 # 9
it is useful to look at the air of the tires
08.05.2020 18:06 # 10
outlaw
RESPECTS
I KNOW I KNOW THAT I HAVE EXPERIENCED WHEN I HAVE 206 HDI, THERE WAS SPIN WHERE I WAS LIGHT GAS IN THE ROTARY JUNCTION.
Hence, we went from IZMIR to ISTANBUL and immediately got off the balance bar.
HOW EVEN HOW THEY WERE HAPPENED FALAN ...
outlaw 2014-05-07 16:15:22
08.05.2020 18:06 # 11
koray
tires zero 195 50 15 zr dunlop
08.05.2020 18:06 # 12
koray
already in the squeak coming from the balance bar can be greased in the place where it went
08.05.2020 18:06 # 13
KILIC
All right, master, behind the balance bar, balls are scattered.
