My 106 sheet rim is not heavy or my gti rim |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Wheel Tire Selection | |
| 08.05.2020 15:45 | # 1 |
tayfur |
In addition, my tires use the 165.64.14 gti rim, usually using thick base tires. |
| 08.05.2020 15:45 | # 2 |
[QUOTE = tayfur] friends, I did not weigh it out, but I know if the 106 quik sheet wheel is heavy or I know my 106 gti wheel, the original 7.5 but I am curious about the kilogram of the replica gti wheel. In addition, my tires use the 165.64.14 gti rim, usually using thick base tires. [/ QUOTE] there is not much difference. The 106 is the best rim that will be quike. It does not cut performance, does not force the car, and does not reduce comfort. |
| 08.05.2020 15:45 | # 3 |
The steel rim is lighter than normal, it is bent, for example, it is in the bus. The steel rims are much more effective than normal, and both fuel drops and provides at least 1 gear on the ramp.
| 08.05.2020 15:45 | # 4 |
I also have a quik, and the wheels are 15 bwa wenom tire size 195 45 15 despite this, the vehicle is going well, but if the original wheels were on it, the vehicle will be lighter. For the Gti rim and the sheet rim comparison, the sheet rims are lighter.
