Must Winter Tire In Inspection?
08.05.2020 20:07 # 1
doganatak
Good night, there are examinations at 20th of this month. Do they want winter tires?
08.05.2020 20:07 # 2
Narkotik
Mandatory for commercial vehicles, the thickness of the teeth is important if the car has summer tires.
08.05.2020 20:07 # 3
x571
[QUOTE = Narcotics] Mandatory for commercial vehicles, the thickness of the teeth is important if the car has summer tires [/ QUOTE]
How do we learn whether the depth of the tooth passes or not?
08.05.2020 20:07 # 4
doganatak
[QUOTE = x571] [QUOTE = Narcotics] Mandatory for commercial vehicles, tread thickness matters if the car has a summer tire [/ QUOTE]
If I am not mistaken, the external depth must be 1,6 mm (I corrected it) doganatak 2017-01-08 23:04:03
08.05.2020 20:07 # 5
The depth of a new tire is around 8 mm. If it fell below 4 mm, there may be a problem.
08.05.2020 20:07 # 6
x571
[QUOTE = sonerkyl] The depth of a new tire is around 8 mm. If it fell below 4 mm, there may be a problem. [/ QUOTE]
We know how it came to that mm.
08.05.2020 20:07 # 7
doganatak
[TUBE] d9-bsghrcdk? T = 7m46s [/ TUBE]
7:46 also talks about tread depth says 1.6mm I corrected my previous post
doganatak 2017-01-08 23:03:38
08.05.2020 20:07 # 8
x571
[QUOTE = nature] [TUBE] d9-bsGHrCDk? T = 7m46s [/ TUBE]
Does anyone know how to measure?
08.05.2020 20:07 # 9
doganatak
[QUOTE = x571] [QUOTE = nature] [TUBE] d9-bsGHrCDk? T = 7m46s [/ TUBE]
Does anyone know how to measure? [/ QUOTE]
If you have a caliper, you can measure it with the back of the caliper, or you have small tools that measure the depth of the tooth, or you will insert a matchstick and stick a nail to the place where the tooth ends, and then you will measure that part of the match.
