Music System Upgrade For Peugeot 206 ...
08.05.2020 15:05 # 1
C!N
Hello friends;
I own a Peugeot 206 vehicle. The music system of my vehicle is not enough anymore and I want to go for improvement, I need the advice of experienced and knowledgeable friends.
Except for the Eonon E837 model in-dash main unit that I use in my car, everything is original products on behalf of the sound system. The idea in my head is to apply Jbl Gto 6508c model 16.5 cm components on the front doors and Jbl Gto 508c model 13cm components on the rear doors and then feed them with the Jbl CS 60 * 4 amplifier in my hand, and then Magnat 30 cm in my hand. I want to be able to use the closed glass box subwoofer with mono amp.
What I want to learn from you, what are your thoughts for such a system. Your opinions for the components I intend to buy, are there any among us, is the amplifier in my hand enough to feed these 2 sets of components, is there a way to connect my subwoofer to this amphith without the 2nd amplifier, which cables will I need for these applications and where can I get them? if possible via the internet), what do you suggest to pay attention during the assembly?
Respects...
Kısmet CİN
08.05.2020 15:05 # 2
serkan24577
hello my friend JBL GTO 6508C 16 CM COMPENANT rms value nice 70 wat rms have good market price 139 tl JBL GTO-508C MYTH SET COMPONANT rms value nice 55 wat rms available market price 131 tl you can feed compenates with 4 channel amps in your hand, but you can feed the compenates with the only channel mono to feed subwore If you have a bass possibility of 250 rms you need to get the amp, JBL GTO 3501 MONO BASS ANPHIEE You can stand with 350 wat rms amp, you can easily lift it, hop it, even if you say no, I will change it in the future, I will get bored, less income, voice message, let's set something more solid.
respects
08.05.2020 15:05 # 3
dinoco
Just take a jbl 301.1 mono amp for your magnat bass.
The price is between 75 and 150 TL.
It will work between 50 TL and 100 TL on equipments such as cable installation insurance.
But your (+) cable from the amplifier should be 10awg, so that your headlights cannot be curled at night.
With this current system, there is no need to have a good lecture.
08.05.2020 15:05 # 4
g-demir
[QUOTE = dinoco] jbl 301,1 just take a mono amp for your magnat bass ..
Can you tell us a little bit about that awg thing? what is this awg? for what reason should it be? I have 6ga cable how much does it work?
08.05.2020 15:05 # 5
dinoco
The unit abbreviation that expresses the cable thickness technically is the usa cable measurement unit.
It draws the energy required for the system more clearly. If the wire inside your cable is less, the awg side is less that it cannot draw the current required by the amplifier instantaneously. I think 2 amps will be driven in your friend's system.
I had previously taken 6 awg like you, the headlights were falling at night. I went to 10awg a little bit, I put the last point with the last 2.5 farat cap .. I hope I could express
08.05.2020 15:05 # 6
C!N
Thank you guys very much for the information.
[QUOTE = serkan24577] hello my friend JBL GTO 6508C 16 CM COMPENANT rms value has nice 70 wat rms market price 139 tl JBL GTO-508C MYTH SET COMPONANT rms value has nice 55 wat rms market price 131 tl you can feed compenates with 4 channel amps at hand but subwore you need to buy a single channel mono amplifier to feed it. If there is a possibility of bass 250 rms.
respects
The prices you give are really reasonable, the best price I can find for 6508C is 168TL, is it possible for me to find out where you got these prices.
Also, I have no idea to develop it in the future, I think this system will satisfy me, in terms of the acoustic quality in the cabin. I plan to ride and change for another 3 years, so I don't want to spend a lot.
08.05.2020 15:05 # 7
C!N
date ...
