Music System (I need information)
08.05.2020 16:43 # 1
herry
Hello friends, I wore the necvox screen on my 206 vehicle, but it was very insufficient compared to the original 206 tape. It's okay in terms of image and feature but as the sound power of the 206's origin. he can't get near the tape. what would you suggest, would a quality amphitheater correct? I have jbl bass in my anif, but i can't understand how much it makes difference. I went to the sound system, I do not know how many channels I will wear the new amplifier, he said, 500 TL, a pale figure, I already got necvox at that price. I put my tape back on. & nbsp; (let me give a small note; the height of the original tape's radio sound is better than the necvox gives on cd)
08.05.2020 16:43 # 2
Alicilik
If you specify the brand model of your current tape and the brand and model of the amphitheater in your hand, we can help you with that. You cannot feed speakers with this amplifier.
To get a sound level above the original, you need to change your normal speaker. Then you feed them with a 4 channel amplifier and you feed the other jbl amplifier and jbl column. You will get very loud sound, no matter the original-necvox. If you say I want quality sound, then you need to cut some more money and buy proven tapes of alpine-pioneer-sony-kenwood-clarion style.
08.05.2020 16:43 # 3
herry
[QUOTE = ScHerZo] It is your event that has become the stew account of cheap meat.
If you specify the brand model of your current tape and the brand and model of the amplifier in your hand, we can help you with it. is the mono amphitheater in your hand. You cannot feed speakers with this amplifier.
To get a sound level above the original, you need to change your normal speaker. Then you feed them with a 4 channel amplifier and you feed the other jbl amplifier and jbl column. You will get very loud sound, no matter the original-necvox. If you say I want quality sound then you need to cut out a little more money and buy proven tapes like alpine-pioneer-sony-kenwood-clarion.
thank you for the answer tape model; NECVOX In-Dash DVA-6806HD, anfi JBL mono amplifier there are 2 new speakers in the front. The back ones did not touch the original pejo speaker. without the original tape amplifier, I think it feeds better than necvox.
08.05.2020 16:43 # 4
sote
the situation you are talking about is very annoying. sote 2012-04-22 15:55:14
08.05.2020 16:43 # 5
Alicilik
Your situation is a bit complicated.
Anfi is necessary or unnecessary to look at the speakers you use. I know the normal tape output is 28w fln. Apparently the indash's is lower. I don't know how to get a 30-40w amplifier just to give indash sound, it's a matter of opportunity and pleasure. It won't taste much.
You must have a good level of mono. If you can find stereo 4-channel amplifier in its equivalent. You bridge the two channels of it and feed the bass. In 2 channels, you feed the festive lower level comp + oval to the houses. There is a system similar to this, we let the wood burned last night. Reviews & nbsp;
08.05.2020 16:43 # 6
herry
For example, in the original tape, the subwoffer officially puts its weight. When necvoxda brings the sound to the end, it gives half of the original tape. :(
08.05.2020 16:43 # 7
Alicilik
Have you tried changing the amplifier settings? Increasing the gain may be beneficial for bass.
For a quality sound, your priority should be good. As a result, other equipment will use it and reveal things. Reviews
08.05.2020 16:43 # 8
herry
let me try what you are talking about. thank you
