music system advice
08.05.2020 16:44 # 1
m1976k
Dear friends, cd player, usb and card reader & nbsp; I'm also looking for a tape that is compatible with the original steering wheel control, I am waiting for your suggestions ...
08.05.2020 16:44 # 2
m1976k
current friends ...
08.05.2020 16:44 # 3
oguzhan29
pioneer wr output tapes, you also have tools to attach to the wr output.
08.05.2020 16:44 # 4
EmSul
Pioneers need a separate apparatus, almost a tape is worth it, it is very expensive to give the apparatus. vehicle-electronics-xetec-CDM-1284-c-cdmp3-kartaux-inputs and-they-usbsd 55,225,056 / details / Reviews
08.05.2020 16:44 # 5
m1976k
I am waiting for friends with other advice ..
08.05.2020 16:44 # 6
Alicilik
There is a friend on the forum for Pioneer.
No pionner tape with wr (wired remote) input Get a model you like and & nbsp; The friend whom I gave the nickname in the car is very cheap.
I am using 9350 I took the video
[tube] http://www.youtube.com/watch?v=K_fAJd_Qadk [/ tube]
08.05.2020 16:44 # 7
m1976k
Thank you my friend ....
08.05.2020 16:44 # 8
ahmet_ankara29
& nbsp; I have a 5-cd player and it doesn't work well. If I put the 5-player cd player and put the mp 3 player tape in its place, can I continue to control it from the steering wheel control.
08.05.2020 16:44 # 9
Alicilik
There is no such thing as electronic can not be done. "Big
My advice is always new tape. I don't know how long the original mentality is.
ahmet bey,
You buy tape instead of changer. At the same time, both the original and the new tape work. there is a handicap for the remote alone;
Cherno is using a series of operations to make the controller compatible with pioneer tapes. During this process, the vehicle and the control lever & nbsp; no interaction left. Your original controller will not affect your original tape after this process. The opportunity to have it will be with a piece you will buy from abroad, and this is an expensive operation, believe it. In some vehicles, the system is connected to the original tape, parking sensor, etc. Therefore, without disconnecting the tape, they just take a separate line and put the oem tape into the torpedo. Then this system is made, the original tape becomes an ornament.
08.05.2020 16:44 # 10
ahmet_ankara29
[QUOTE = ScHerZo] There is no such thing as electronic. "Big
My advice is always the new tape. I don't know how long the original mentality is.
ahmet bey,
You take a tape instead of a changer and plug it in. At the same time, both the original and the new tape work. There is a handicap for the remote alone;
Cherno is implementing a series of operations to make the controller compatible with pioneer tapes. During this process, the vehicle and the control lever & nbsp; no interaction left. Your original controller will not affect your original tape after this process. The opportunity to have it will be with a piece you will buy from abroad, and this is an expensive operation, believe it. In some vehicles, the system is connected to the original tape, parking sensor, etc. Therefore, without disconnecting the tape, they just take a separate line and put the oem tape into the torpedo. Then this system is being made, the original tape becomes an ornament. To be able to use the player with the player at the same time to use the remote
08.05.2020 16:44 # 11
Alicilik
What is the brand and model of the tape you have?
08.05.2020 16:44 # 12
tigerland
[QUOTE = m1976k] I am waiting for friends with other advice .. [/ QUOTE]
I bought Pioneer 1400 UB from technosa. I sent the arm to izmir, a friend doing this job. I took it to 35 TL, thanks to it. I use it like. Like a little system :)
08.05.2020 16:44 # 13
ahmet_ankara29
[QUOTE = ScHerZo] What is the brand and model of the tape you have? [/ QUOTE] jameson js 5000
