Multiply the braking distance in the snow by 8
Homepage » PEUGEOT MODIFIED PLATFORM » Useful Documents
08.05.2020 14:09 # 1
Multiply the braking distance in the snow by 8 The braking distance, which is 8 meters at a speed of 50 km on dry road, increases to 64 meters on ice. Winter tire stands 31 meters earlier on snowy ground than summer tire. All Turkey` against snow and ice affecting the tire giant Michelin, gives important tips for safe driving in the snow ... its influence in all dorm for a week increase snowfall and icing Istanbul, forcing more traffic. Although it is imperative to have a chain in the traffic law, the cars keep the winter tire on the road. Experts say that the risk of accidents in winter increases by up to eight times compared to summer, depending on weather and road conditions. It is known that one of the most important ways to prevent this is the tires, the only point of the car's contact with the ground. Below 7 degrees of danger With the heavy snowfall in the country, the driving safety of the vehicles on the roads and concerns about staying on the road increase. Trying to inform consumers about the use of tires in the winter with the website www.yedidereceninaltinda.com, Michelin emphasizes that the winter season begins under 7 degrees for tires. When the temperature is below 7 degrees from November to April, the rubber of the summer tires hardens and loses its effectiveness. For this, it is necessary to use winter tires from November to April. The winter tire provides more safety below 7 degrees and shorter braking distances on any type of ground than the summer tire. Braking distance on snowy ground at 50 km / h is 63 meters in summer tires and 32 meters in winter tires. So 31 meters extra is required to stop with the summer tire. If an automobile is counted on average 4.5 meters, the winter tire saves drivers from hitting seven cars. “Do not buy two tires” In winter, drivers install winter tires mostly on the front or rear tires of the vehicle, depending on the traction direction of the vehicle, in order to improve performance on take-off. However, these two winter tires only provide traction. Four winter tires are recommended to keep the vehicle under better control. In a front-wheel drive vehicle with winter tires fitted only at the front, there is an imbalance at the rear while the risk of skidding increases. If the winter tires are fitted on the rear only, a rear wheel drive vehicle will experience imbalance at the front and risk of not cornering. It has 1500 channels Air temperature directly affects tire air pressure. The lower the air temperature, the lower the measured air pressure. In order to meet the low air temperature in the winter months and to drive with the correct air pressure, 3PSI (should be measured when the tire is cold) needs to be added to the daily use pressure or other (charged) use pressure. The winter tire provides road grip with a tread pattern on it. Capillary channels, which are 200 in summer tires, increase to 1500 in winter tires. No need for the chain, but ... The winter tire does not harden and freeze at an air temperature between plus 7 and minus 38 degrees. Since it maintains its softness, it also eliminates the need for chains. However, there is still an obligation to wear a chain in the relevant Traffic Regulation. Drivers who do not need the chain in any way because they wear winter tires must still have a chain in their vehicles as per the regulations. * Driving in the snow: Increase the distance to the vehicle in front. To avoid skidding when climbing uphill, opt for higher gear than in dry weather. Avoid sudden movements, sudden brake impacts and very high speed. * Brake: If necessary, alternatively it is necessary to brake using the engine brake and brake pedal. The gradual brake prevents the wheels from locking while preventing the vehicle from slipping and loss of control. * Take Off: To reduce the risk of skidding during take-off on snowy ground, it needs to be accelerated gradually. If skidding, reduce the force applied to the wheels and shift into the top gear to steer the vehicle. * Bend: Limit your speed by taking care to slow down in a straight line before entering the bend. While cornering, keep your steering movement soft and steady to ensure that the tire leaves the road and responds to your commands. Braking distance on snowy ground at 50 km: * Summer tire: 63 m * Winter tire: 32 m * Difference: 31 m
08.05.2020 14:09 # 2
FTH
Very important information Beautiful sharing thanks Emrah ..
08.05.2020 14:09 # 3
Onur
thanks for sharing
08.05.2020 14:09 # 4
Murat
Nice sharing Emrah.
Also, do not traffic on snow or ice. Although you may be careful, there will be a high risk of accidents at any moment as there will be very novice around.
08.05.2020 14:09 # 5
Can Duzyatan
When I say snow ..? Dil Çıkarma
If we knew how, we take precautions KahkahaKahkaha
08.05.2020 14:09 # 6
firat.pj34
[QUOTE = Can Düzyatan] When I say snow ..? Dil Çıkarma
If we knew how, we take precautions KahkahaKahkaha [/ QUOTE]
it was nice SırıtmaSırıtma
08.05.2020 14:09 # 7
shamed
thanks for sharing
