Multimedia system
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Partner tepee
08.05.2020 19:23 # 1
tanerkaya
Friends I would like to get a system for my 2013 Partner Tepee Allure, which includes navigation, multimedia, TV, and a reversing camera. When I saw a few places, I got information that the iphone (from usb) charge could not be done and that it would be necessary to use it from the exit output. It did not make sense to give this much money and do the charging again in the old way. Is there a brand-model-system etc. that you can recommend? (the price I received is 900 TL including the assembly)
I searched the image system for the headrests, it should be compatible with the multimedia that I would get, for example, it should be able to be watched from the backheads while watching TV, and it should be able to charge the iPhone again. I received a total price of 350 TL for two heads and their mounting. Do you have any other advice?
Thank you for your help
Taner Kaya
08.05.2020 19:23 # 2
madblueblacksea
I would like to hang on the subject of charging. There is no such thing as USB charging. Charging a device with a normal charger 5V 2amps with 5v 0.5 amps will damage both devices. USB 3 gives 1 amp in the system, but even that is not enough.
08.05.2020 19:23 # 3
tanerkaya
Thank you for the information madblueblacksea
08.05.2020 19:23 # 4
madblueblacksea
[QUOTE = tanerkaya] Thank you for the information madblueblacksea [/ QUOTE]
You're welcome. The values I provide are standard USB values. As Exra, I can not say anything if there are additions for charging on the device, but I have never come across. I try not to stay away from technology as much as I can and I have electronic knowledge and experience at the level of journeymen
08.05.2020 19:23 # 5
tanerkaya
Thumbs Up
08.05.2020 19:23 # 6
Aslan besleyici
https://www.facebook.com/karatutlu/videos/10217256457301636/uzpfstexnzc4nza0odm6mtaymtgzmzgxnjk4mjm3nzm/
08.05.2020 19:23 # 7
Aslan besleyici
The device I invented through the saving mode
