Mr. Bsi malfunction
08.05.2020 15:14 # 1
formulaone
bsı malfunction for 1 week he put me in my car, I was hurting my car.
08.05.2020 15:14 # 2
bestfear
& nbsp; Sorry big gaiba .... get well soon ...
08.05.2020 15:14 # 3
Can you give some more information? How did it happen, did it fail or not? You understand how BSI is etc.vs.
08.05.2020 15:14 # 4
Get well soon. It's really sad to be on the road. God give patience.
If you can give information about how it is, let us take precautions in situations that are likely to happen to us. Take action if possible.
& nbsp;
NOTE: It may be irrelevant but every malfunction that appears bsi malfunction does not bsi malfunction. In my vehicle, BSI was constantly detecting from the brakes. The service said the new BSI will be installed. Thanks, I called Murat from Izmir. I was going to change it, but Murat master had told me to talk to the service and ask if they would get the brain back if the old brain persists and if the old brain continues, act accordingly. I asked the service, they said we would definitely get the money. I gave up too. It turns out that it was a situation related to the brake sensor. We took care of a good autoelectrician for 30 lira.
& nbsp;
Get back again.
trap 2011-04- 09 11:15:11
08.05.2020 15:14 # 5
I guess as we talked to you last night, there is water coming in there. I think this is a situation that is generally in the 307s. others have had the same trouble. The water that needs to come down through the hole on the sofor side comes into the vehicle. it is malfunctioning because it is at that point.
I guess you didn't say what you did in rainy weather or when the car was washed, didn't you? or do I remember wrong ??
08.05.2020 15:14 # 6
[QUOTE = cecoli] I guess as we talked to you last night, and there is water coming in there. I think this is a situation that is generally in the 307s. others have had the same trouble. The water that needs to come down through the hole on the sofor side comes into the vehicle. it is malfunctioning because it is at that point.
How does it rain on BSI? Confused Then you need to take action.
08.05.2020 15:14 # 7
[QUOTE]
How does it rain on BSI? Confused Then you need to take action. [/ QUOTE]
I'm not sure about that. I convey as much as I know from others' writings. There is a hole in the left wiper. water should normally descend from there to the ground. But somehow there is water coming from somewhere to the side of the sofor. Since it is at that point, there is contact with the water ... I don't know if it happens every 307. but I remember this information from other people's ...
08.05.2020 15:14 # 8
It happened to me personally. I had also posted on the forum at the time, and at that time you did not know that there was such a possibility. Sec. As cecoli said, there is a plastic cover with a hole in the bottom of the mosque to the left of the mosque. There is something like a plastic stopper when looking inside the cover. Of course, that plastic loses its function, it hardens, and it can leak water from time to time. There is BSI just below the rate in your opinion "Don't When the water is taken, the car starts to make moves. For example, when I was stopping in mine, no gasoline was exhausted, no automatic wiper was activated, no I know what error occurred. They siliconize that plastic part and the problem is solved. In fact, big mistakes in our vehicle can be caused by minor problems.
koliva 2011-04-09 11:31:53
08.05.2020 15:14 # 9
[QUOTE = koliva] It happened to me personally. I had also posted on the forum at the time, and at that time you did not know that there was such a possibility. Sec. As cecoli said, there is a plastic cover with a hole in the bottom of the mosque to the left of the mosque. There is something like a plastic stopper when looking inside the cover. Of course, that plastic loses its function, it hardens, and it can leak water from time to time. There is BSI just below the rate in your opinion "Don't When the water is taken, the car starts to make moves. For example, when I was stopping in mine, no gasoline was exhausted, no automatic wiper was activated, no I know what error occurred. They siliconize that plastic part and the problem is solved. In fact, big mistakes in our vehicle can be caused by minor problems.
& nbsp;
I heard this problem from a considerable person ...
08.05.2020 15:14 # 10
zubeyir35
Where is this hole, I wonder if there are pictures of it, let's silicon it without water ... I heard it in the car, especially in rainy weather when water enters the water quickly, and the water is going to eat the head ... there are no brands other than the pejo but we love the pejo :)
08.05.2020 15:14 # 11
hhuzun
GET WELL SOON
08.05.2020 15:14 # 12
[QUOTE = koliva] It happened to me personally. I had also posted on the forum at the time, and at that time you did not know that there was such a possibility. Sec. As cecoli said, there is a plastic cover with a hole in the bottom of the mosque to the left of the mosque. There is something like a plastic stopper when looking inside the cover. Of course, that plastic loses its function, it hardens, and it can leak water from time to time. There is BSI just below the rate in your opinion Ağlama When the water is taken, the car begins to make metal movements. For example, when I was stopping in mine, no gasoline was exhausted, no automatic wiper was activated, no I know what error occurred. They siliconize that plastic part and the problem is solved. In fact, big mistakes in our vehicle can be caused by minor problems.
So, can you photograph your father in a suitable time so that we can fully understand this place? If it is something we can do, let us do it ourselves, or take it to a master and describe it so that he can do it, we will not have any trouble. If there is such a problem, it is necessary to take precautions.
08.05.2020 15:14 # 13
bestfear
The friends told me about the leakage of water to the bsi in the private service ... There are perforated water drainage sections on the right and left sides of the windshield ... the caps come out very simple ... when the expenses in these sections are blocked, water accumulates inside the level of the water that goes to the driver's side. When it rises up to the cable hole, it takes water inside ... There is a fuse table and Bsi under the place where the water escapes ... If no measures are taken, the damage can be great ...
Solution :
* Keeping these drains open all the time so that water does not accumulate there.
* Sealing the holes opened inside to prevent the water that can accumulate inside.
08.05.2020 15:14 # 14
[QUOTE = bestfear] Friends told me about the leakage of water to the bsi in the private service ... There are perforated water drainage sections on the right and left sides of the windshield ... the lids are very simple ... the water accumulates inside these sections when the expenses in these sections are blocked. When the driver's level rises up to the cable hole that goes to the side of the driver, he gets water inside.
Solution :
Yes, this is the best solution ... Alkış
There are similar problems in the 306s. Similar problems occur if both sides of the vehicle get clogged. If the sofor side is blocked, the engine that will fill and wipe the water burns, and water can enter from the point where the installation is located. If water is poured on the right side, the top of the heating engine is hot and can run up to the mop ...
08.05.2020 15:14 # 15
metin
I hope the problem is solved simply.
Did you meet with Eyüp Duygun from the forum sponsor? he was repairing chips and bsi
08.05.2020 15:14 # 16
bestfear
[QUOTE = cecoli] [QUOTE = bestfear] Friends told me about the leakage of water to bsi in the private service ... There are perforated water discharge sections on the right and left sides of the windshield ... the covers are very simple ... the expenses in these sections are blocked. when water accumulates inside the water level rises up to the cable hole of the driver's side, it takes water inside ... There is a fuse table and Bsi under the place where the water escapes ... damage can be great if no action is taken ...
Solution :
Look what came to my mind now ... I had siliconed the left in my car ... I did not need the right ... recently the right mat had six lakes ... The car did not decrease any water from the heater ... Door tires are solid ... ???? I couldn't detect the fault somehow ...
Maybe the reason for the water is getting water from the drain on the right side .... I am siliconized right there ...
08.05.2020 15:14 # 17
@ bestfear = happy if we found a solution to your problem in the meantime :)))))
08.05.2020 15:14 # 18
bestfear
[QUOTE = cecoli] @ bestfear = happy if we found a solution to your problem in the meantime :) )))) [/ QUOTE]
Hopefully it has been found ... I bought the car beautifully, but a simple water intake caused me a lot of trouble ... I had the mop every day ... :))
08.05.2020 15:14 # 19
formulaone
My friends are not running the car is running and I have the brain and I have sent the tool to the mouth of the brain, which has caused the moisture to lose its function. The real thing that bothered me was that the vehicle left me on the road, and I gave it to the vehicle, I was obsessed, I was looking at my eyes, and I changed this fault, I made the car go crazy and wait for a piece from the service. I made all the faults of the vehicle that I will give to the owner. The new vehicle will be comfortable. Let me see if it is a fortune, but with the best regards I will be between you on the 17th of the month and in Thrace: :(
08.05.2020 15:14 # 20
Anyway it was very costly, but I am glad it was solved. basically it is very simple but how does pug make such a deficiency crazy part: ((
Choose yours, but be sure there are similar malfunctions in other brands. last night the brand new bmw i saw the hunters ramping up the ramp and were trying to pull right. I couldn't see it exactly, but I think it was 316. the smallest malfunction because it increases by going electronically remains in click :))
Page : / 2
