mp3 or track
08.05.2020 17:34 # 1
scepter
my teacher also has 206+ I went for rds, they said they are not available in these models. is running
08.05.2020 17:34 # 2
Barut
As far as I know the track is playing, mp3 does not.
08.05.2020 17:34 # 3
Gokhan Cetin
yes, it does not play mp3, you should write or print it as a track cd, that is, track
08.05.2020 17:34 # 4
samet206
These types of tapes are playing the track as well, you will prepare tracks with a maximum of 10 - 15 songs. You will be using nero from that way or you will use the original cd. 90-100 songs that are prepared as an mp3 do not play. It will be more logical to get efficiency. I don't know if there is a way to play mp3 cd to tape recorders.
08.05.2020 17:34 # 5
scepter
If we take tape, can I use the steering control & nbsp; or are there tapes compatible with that controller?
08.05.2020 17:34 # 6
samet206
[QUOTE = scepter] can I use the steering control & nbsp; if we get a tape recorder & nbsp; or are there tapes compatible with that controller [/ QUOTE]
Unfortunately, the room is not possible. If you find it from repair and if it comes from your tongue, it will be able to make a beautiful assembly that recognizes the product it sells, or if it comes from your hand, you can only use the joystick thanks to the apparatus.
08.05.2020 17:34 # 7
Alicilik
[QUOTE = scepter] Can I use the steering wheel control & nbsp; if we get a tape & nbsp; or are there tapes compatible with that controller [/ QUOTE]
1- Your current cd player only plays AudioTrack CD. File types such as mp3-wma do not play. You should burn the CDs yourself in a proper program. Open CDs do not play. I know that RW does not read CDs
2-RDS does not know service. They have to activate from the menu about Diagbox.
3-If you want to run mp3, there is a system applied to the CDChanger input of the tape. It is called AudioSystem. Serco05 (serkan) brother knows well helps you. You can take this apparatus anywhere you want. If I'm not mistaken, there are USB-SD card and Aux inputs. How you use the normal tape How do you use the CD?
4-If you say I can change the tape completely, the tape you received should have a W_R (wiredremote) entry. The cable is pulled here by an operation on the control lever of the vehicle or you can bring parts from abroad. The cost of the control arm should be 30-40tl, making a friend in Izmir. If you want to buy other types of parts (no disassembly or mounting, you only connect to the cables of the tape as a bridge), it was 80-90tl.
08.05.2020 17:34 # 8
SDYMZ
[QUOTE = Recipient]
4-If I say I can change the tape completely, the tape you received must have a W_R (wiredremote) entry. The cable is pulled here by an operation on the control lever of the vehicle or you can bring parts from abroad. The cost of the control arm should be 30-40tl, making a friend in Izmir. If you want to buy other types of parts (there is no disassembly or mounting, you only connect to the cables of the tape as a bridge), it was 80-90tl.
this is very good. Well, does the text appear like an original tape on the screen with the bosom?
08.05.2020 17:34 # 9
Alicilik
[QUOTE = SDYMZ] [QUOTE = Recipient]
If you say I change the tape completely, the tape you received must have a W_R (wiredremote) entry. The cable is pulled here by an operation on the control lever of the vehicle or you can bring parts from abroad. The cost of the control arm should be 30-40tl, making a friend in Izmir. If you want to buy other kinds of parts (no disassembly, just connect to the cables of the tape as a bridge) it was 80-90TL.
this event was very good. Well, does the screen appear like an original tape on the bosom screen? [/ TUBE]
Alicilik 2013-05-05 22:57:46
08.05.2020 17:34 # 10
rolandgarros
[QUOTE = Receiving] [QUOTE = SDYMZ] [QUOTE = Receiving]
If you say I can change the tape completely, the tape you received must have a W_R (wiredremote) entry. The cable is pulled here by an operation on the control lever of the vehicle or you can bring parts from abroad. The cost of the control arm should be 30-40tl, making a friend in Izmir. If you want to buy other kinds of parts (no disassembly, just connect to the cables of the tape as a bridge) it was 80-90TL.
this event was very good. Well, does the screen appear like an original tape on the screen?
So there is a system so it is made with very special serial tapes and an expensive apparatus from the tape;
[TUBE] https : //www.youtube.com/watch? v = ggrFcROiZ4w [/ TUBE]
just like the device is expensive than the tape
