MOVEMENT PROBLEM
08.05.2020 17:12 # 1
umut_25
Hello Friends
There is an extraordinary situation about heat in my 206 Quiksilver vehicle I just bought. When I switch on the heating system, the temperature drops below 90. It comes from the 80s to the 70s. It rises again after a while after turning off the heating system, but this time it reaches 100 levels above 90. In this case, I turn on the boiler again and turn it off when it reaches 90 levels. Why do you think? If there are friends who have encountered this situation before, I am waiting for their help.
08.05.2020 17:12 # 2
cgty86
I have a similar problem today so I will go to the private service, but my suggestion is, look at the bottom of the driver's mat. Is there any water flow?
08.05.2020 17:12 # 3
umut_25
Ok let me see. Well, would you inform me after you came from the service?
08.05.2020 17:12 # 4
MagicPerformance
this is not a problem, up to 100 overheating is normal, over 100 problem
08.05.2020 17:12 # 5
umut_25
Allla allla: S
08.05.2020 17:12 # 6
soneroo
this is quite normal, usually peugeot fan turns on at the level of 100 to 110 there is no fear to be & nbsp; When the temperature of your vehicle is increased, you open the heating system and give the engine heat inside. If you turn on your air conditioner, your motor temperature will not rise because the fan is always on.
08.05.2020 17:12 # 7
umut_25
But when the heater is off, the temperature hand, which should normally remain at 90, falls from the 80s to the 70s.
08.05.2020 17:12 # 8
soneroo
It may not be an important thing that your vehicle's thermostat is opening before 90.
08.05.2020 17:12 # 9
zamboglu
hello I have 307 sw 2003 too, the temperature indicator is just like you mentioned. I also researched at first and learned that these cars are normal. I don't mind now.
08.05.2020 17:12 # 10
Zagorka
It Could Be In The Radiator Fan, 90 Is Not Too High & nbsp; So Don't Wear It, Of course Not So Normal But But ... & nbsp;
08.05.2020 17:12 # 11
MagicPerformance
It is supposed to be up to 90-100 regular lines. & Nbsp;
08.05.2020 17:12 # 12
albayman
The climate characteristics of each peugeot vehicle may not be the same. Someone who claimed that they knew the gras of these vehicles told me that my vehicle was set to temperate climatic conditions. While the vehicles were being produced, they were adjusted according to the climate conditions of the country they will be sold. I don't know how true, but it sounded logical.
But 16-valve vehicles usually work at high temperatures to lower fuel. fans open around 100. Reviews
