MOVEMENT OF THE WIPERS WHEN THE 307 VEHICLES LOAD
08.05.2020 19:55 # 1
beratsinaner
Hello friends, I have a 2006 makeup case 307, I love my car, I have been using it for 8 years without any problems, until the ignition coil changed, the coil left me on the highway one day and the coil changed now, there is a shake in my car, they will wipe especially during unloaded departures while the truck is not enough. It moves upwards 2-3 times after doing it, the wipers turn on and off completely once, I am waiting for your help if you have encountered this problem before, thank you ...
08.05.2020 19:55 # 2
first of all we are welcome. If your vehicle has changed the spark plugs after the coil change, first check it. If the coil has not changed, the coil may be zero but malfunctioned. Have it checked again. When it comes to wiper problem, if your car has a rain sensor, it may be a problem with the sensor or com2000 headlight wiper arm problem. have the battery checked also.
08.05.2020 19:55 # 3
beratsinaner
thank you sonerkyl ... I suspect the spark plugs and the coil, the main problem is the fact that the wipers move on their own, I don't think there will be any rain sensor in my car because I thought it would be related to the wiper arm, because I do it when the car is on and off ...
08.05.2020 19:55 # 4
You can also check the charge dynamo in the vehicle as there is voltage imbalance.
