Movement of the temperature hand
08.05.2020 20:35 # 1
spycan
My vehicle is also at LPG 109,000. While cruising (2 times so far), the temperature pointer turns red and the buzzer stops and the buzzer sounds and the fan is activated. When I pull my foot out of the gas to stop when I see the stop text, the pointer also drops to 0, the stop text and the warning sound disappears,
when I press the gas again, the pointer comes to 90 and remains steady. The fan keeps running when I stop the vehicle. the fan stops after cooling is finished.
All these things happen in 5-6 seconds.
The vehicle did not cause such problems or coincided with performance use
Has there been any such situation?
Why do you think it might be?
08.05.2020 20:35 # 2
my teacher may have a problem in overheating. there may be air in the cooling system. the thermostat may be faulty. First of all, if the vehicle has a malfunction code, have it checked.
08.05.2020 20:35 # 3
erdiano
If the thermostat is broken, does it give the fault code when it connects to the computer?
My car is 2006 model 307 1.4 comfort and I think my thermostat is broken. The temperature indicator in my car does not exceed seventy, even if I go 70-80 km. In the case of stop, run, stop and run in the city, 90a comes only. I used it all summer, even when I read the articles on the forum that peugeots like to work hot and about the danger of burning gasket, it sounded good, but the weather got cold. It started to be a problem when he could not get the hot air after a few minutes when he got into the car Big smile vehicle lpgli. I think the fact that the thermostat is broken also increases fuel consumption.
08.05.2020 20:35 # 4
spycan
the heat sensor of the vehicle is broken. I'm waiting for the piece to come. The sex side of the job I ordered the part and the car stopped doing the heat. :D
08.05.2020 20:35 # 5
whisky
The fact that the thermostat is broken increases the fuel consumption, because when it is on, the engine cannot cool to the optimum temperature for combustion because the engine is constantly running cold. accordingly, wear also increases. the thermostat does not give a malfunction code when it is broken. There are several ways to find out that it is already corrupt.
