Movement indicator problem
08.05.2020 21:23 # 1
Berkant5999
Hello friends, I have a 206 1.6 2001 model and my problem is that even if the car does not overheat, the indicator is blinking in red, the stop light is blinking. Do you know where the problem is?
08.05.2020 21:23 # 2
Ahmet307
the oil pump is defective I have the same error I was giving an error when the cycle was low.
08.05.2020 21:23 # 3
Berkant5999
If it was an oil pump, would traction not fall? No shrinkage or loss in traction.
08.05.2020 21:23 # 4
Berkant5999
Isn't there anyone who faces this problem Sleepy
08.05.2020 21:23 # 5
Orcun.Dmr
Have you looked into the socket attached to the temperature sensor? If you haven't looked at it, the cable is probably broken from inside the socket.
08.05.2020 21:23 # 6
Berkant5999
I solved the problem teacher, the radiator wing was clogged, I cleaned the thermostat, I couldn't worry.
