MOVEMENT INDICATOR IS NOT ACTIVE VEHICLE DOES NOT WORK
08.05.2020 19:51 # 1
prens63
MASTERS HELLO MY 2003 MODEL PEUGEOT 206 1.4 I HAVE MY VEHICLE. WHEN I ATTACH THE IGNITION SWITCH IN THE LAST DAYS, THE VEHICLE IS RUNNING IF THE MOVEMENT INDICATOR RISES UP AND THE VEHICLE DOES NOT WORK IF THE STOP IS DOWN, BUT THE VEHICLE DOES NOT WORK. I SHOWED THE SERVICE TO THE COMPLETE ELECTRICAL INSTALLATION IF THE VEHICLE DOES NOT CHANGE THE INTERNAL FUSE BOX. They said, let's stay, I said, all the money trap. Often the engine runs when it is cold. NO TROUBLE BUT WHEN THE VEHICLE MOVEMENT INDICATOR IS ACTIVE AND DOES NOT WORK, PLEASE HELP? ???
08.05.2020 19:51 # 2
first of all welcome. Well, did you have the temperature sensor checked?
08.05.2020 19:51 # 3
prens63
preview
We are looking at him now, looking at him, the master will change his temperature, brother only that temperature indicator got up working
08.05.2020 19:51 # 4
prens63
I had it checked, we changed it, it was like the hot temper was correct, we started off, the engine warmed up, we stopped, we pressed again, the starter was the same again, my master did not solve it
08.05.2020 19:51 # 5
prens63
When the engine brain plus fuse box desires all health, the harness indicator is running and the car is running, is there anyone to help
08.05.2020 19:51 # 6
ymehmet
Hello, there was also a problem with my car on the subject. We connected the computer to the eccentric sensor error. Thank goodness there wasn't any problem when I changed the part.
08.05.2020 19:51 # 7
ymehmet
By the way, what you call indicator is temperature indicator or tachometer?
08.05.2020 19:51 # 8
Dralp
Did they look at the thermosto?
08.05.2020 19:51 # 9
ymehmet
Does the temperature indicator play without the vehicle I do not understand? Shouldn't it be a while before the vehicle starts?
06.06.2020 01:52 # 10
Sinka
Hello, in my car, the car works when the motion indicator works, it does not work when it does not work, I wonder if you have solved the same problem.
07.06.2020 03:32 # 11
muzzy35
Sinka brother, be aware of the messages 4 years ago, the answer may come late :)
06.10.2021 23:45 # 12
anatolia_20
I have the same problem and the car does not start. who finds a solution, why doesn't he write his solution here?
10.10.2021 23:15 # 13
sozuak
The cam sensor error with error code P0341 causes these types of problems. As the name of the sensor indicates, it is a 3-wire piece on the top cover. First of all, check the cables and any short-circuiting status. They can rot with heat and touch each other. It often happens that it doesn't trigger the check engine light either.
10.01.2022 02:02 # 14
anatolia_20
the problem was from the ecu socket, no contact
