MOVEMENT INDICATOR
08.05.2020 17:29 # 1
ADANALI_01
I HAVE UNDERSTAND THE BATTERY INDICATOR REMOVED THE BATTERY INDICATOR WHEN I FOLLOW THE CONTACT IN THIS MORNING, I REMOVE THE BATTERY POLE HEAD, I HAVE GOT I HAVE I HAVE A PROBLEM ...
08.05.2020 17:29 # 2
ilyas
most likely the temperature sensor is stuck or is out of order.
08.05.2020 17:29 # 3
ADANALI_01
WHERE IS THE SUCCESS FULLY ...
08.05.2020 17:29 # 4
fevzioglu
[QUOTE = ilyas] I think the temperature sensor is probably stuck, or there is no other possibility that it is faulty. [/ QUOTE] I agree with my friend.
08.05.2020 17:29 # 5
fevzioglu
In my car too, the temperature rises over 90, and when I accelerate, it drops to 70s, is that normal?
08.05.2020 17:29 # 6
ilyas
In our vehicles, the thermostat opens at 98 degrees and closes at 92 degrees. this means that 90 degrees is normal. & Nbsp; http: //img137.imageshack.us/img137/967/wrwrw.png at this address in red circle. & Nbsp;
08.05.2020 17:29 # 7
muku
When the discharger is removed, the indicator rises to the ceiling.
08.05.2020 17:29 # 8
ADANALI_01
When I went home in the evening, I removed the plug of the sender again, the indicator was on the ceiling, how can I tell you that this is broken, thank you to all the non-responders, thank you very much ...
