MOVEMENT FROM COLD AIR FROM A RISE
08.05.2020 18:09 # 1
klctlg2603
I live in Afyon. My car is my Partner outdoor 2011 model car. I have a job early this morning and after my car warmed up for 5 minutes, I moved.
When we start the movement, the temperature indicator turns out to be 70 percent and 90 percent. So far no such thing has ever happened in winter.
The temperature of the air is -6 degrees.
08.05.2020 18:09 # 2
klctlg2603
Suddenly, I stopped the car for 15-20 minutes or so, the temperature indicator did not go down.
08.05.2020 18:09 # 3
E.B
I lived the same problem yesterday, mine went over 100 when I was on the road.
08.05.2020 18:09 # 4
klctlg2603
thanks bro we'll see now
08.05.2020 18:09 # 5
baybaba
As far as the best operating temperature of the engine does not exceed 90, 100, there is no problem,
I use Partner Adventure too, because of the ice, there may be some water loss in the crack, sudden
may cause high temperature,
08.05.2020 18:09 # 6
klctlg2603
Thanks bro
08.05.2020 18:09 # 7
[QUOTE = baybaba] As far as I know the optimum operating temperature of the engine, there is no problem unless it exceeds 90, 100,
Stop over 100 traffic, get up to 90-95 max. When going straight it should be 75-85.
08.05.2020 18:09 # 8
klctlg2603
After looking, he did not make the same mistake and I went 250 km and I came and the temperature indicator fell
08.05.2020 18:09 # 9
klctlg2603
no problem now thank you for your help klctlg2603 2013-12-22 23:33:13
08.05.2020 18:09 # 10
ahmet_bjk
If you are using the vehicle at high revs, it is normal for the temperature to increase.
What is dangerous is that the temperature rises above 90 and does not descend.
08.05.2020 18:09 # 11
klctlg2603
I did not use it at high speed or use it
