MOVEMENT FREIGHT
08.05.2020 19:35 # 1
Racon34
Friends, I have a curious topic, I normally see the low temperature in the season, but I have an abnormality in mine, although the temperature gauge does not go up from 70, but if I pause, it goes up from the ground, is it normal? And while this is walking for 1 or 2 hours, it gives very little heat in my heaters. If my hands and feet freeze inside the car, does it really give me the air conditioner?
08.05.2020 19:35 # 2
Barut
The thermostad remained open. I suggest you change as soon as possible.
08.05.2020 19:35 # 3
Racon34
[QUOTE = Gunpowder] Thermostad remained open. I suggest you change as soon as possible. [/ QUOTE]
In other words, I think that the vehicle is constantly cooling itself, I think this cannot be for any other reason and does it cause me a problem?
08.05.2020 19:35 # 4
red 206
Cooling may burn as the fan is constantly actively working. If you do not understand it, if you burn the gasket, there is an important thing, if the failure is not resolved, it will cost you a lot as you go.
08.05.2020 19:35 # 5
Gokcesel
You need to change the thermostat. I don't think you will have a problem for a short time but change it at the first opportunity. There is also a topic in the forum, you can get information here Gokcesel 2016-01-05 22:04:37
08.05.2020 19:35 # 6
Barut
[QUOTE = Racon34] [QUOTE = Gunpowder] Thermostad remained open. I suggest you change as soon as possible. [/ QUOTE]
[/ QUOTE
Proceeding in this way will increase the fuel, and the engine will wear more, since it cannot reach its full temperature. It also falls out of traction. Powder 2016-01-05 22:52:21
08.05.2020 19:35 # 7
Racon34
Thank you, I will tell you, if you give me information tomorrow, you will see it, it will be due to the cold of Ankara.
08.05.2020 19:35 # 8
KnHktn
[QUOTE = Racon34] Friends Something I wondered would normally meet regular to remain low seasonal cold temperature, but there is an abnormality in the mine vehicle 1 2 hour ride to spite heat indicative of çıkmıyo run up to 70 but stops if bi cıkıyor the very least from the ground up do you think is this normal? And it gives very little heat in my calories while I am traveling for 1 2 hours.
Sa. I was living the same thing until yesterday, as winter comes, the temperature should be around 90. When the cold started, I entered the industry and looked at the prices, he said the original was 45 TL for his 20 equivalent. He recommended the original, said important, etc. I know that it will not be a problem as I have not had trouble during the summer. I bought it for 20 TL.
Now my vehicle is warming up faster and I enjoy the warm environment to the fullest.
If you have a number 10 key in your hand, you can disassemble it, but be careful, if you are going to do it while the engine is hot, loosen the light nut and let it bleed.
Have a warm and happy journey Wink
08.05.2020 19:35 # 9
ARDADOGAN
MY SISTER WAS THE SAME TROUBLE, I HAVE IN MY CAR AT 307, I WOULD NOT EXTRACT FROM ANYWHERE AS ANTALYA, I WOULD HAVE ASKED ANYWHERE 70 ANYWHERE ANYMOUSH 1 NO SERVICE, NO REPAIRERS AND THE MOUNTAIN OF THE MOUNTAIN, IF THE PROBLEM IS FAILED, THE FAN DRAFT HAS BEEN INSTALLED WHEN I HAVE RECEIVED THE PLUG OF THE SOUL. NOW THE MOVEMENT HAS BEEN CORRECTED 90 STAYS FIXED I CHANGE THE MUŞUL LEATHER 30LIRAL PARTS HEAD IS COMFORTABLE THE SAME THE PROBLEM OF THE PROBLEM ....
08.05.2020 19:35 # 10
Let's use lower case letters as per the forum rules. good forums
08.05.2020 19:35 # 11
Racon34
[QUOTE = ARDADOGAN] MY BROTHER WAS THE SAME TROUBLE, I HAVE IN MY ARABI, I WOULD HAVE EXTRACTED AS MUCH AS 707 IN ANY PLACE, I WOULD HAVE EXTRACTED AS MUCH AS ANTALYA, I WOULD LIKE ANYTHING THAT ARE THERE ARE THERE A LIKE THAT ARE THERE ARE THE MORE THAT ARE THERE ARE THE MOMENT. UGORDU E WAS PANIC, WE HAVE NO SERVICE, NO REPAIRER AND WE HAVE STAYED AT THE MOUNTAIN. NOW THE MOVEMENT HAS BEEN CORRECTED 90 STAYS FIXED I CHANGE THE MUŞUL LEATHER 30LIRAL PARTS HEAD IS COMFORTABLE THE SAME PROBLEM OF THE PROBLEM .... [/ QUOTE]
My brother, but when I pause when I stop, I don't think it will be from 80 to 90 times when I pause, so as friends say, there is a problem with the thermostat, I will change it in time.
08.05.2020 19:35 # 12
ARDADOGAN
Of course it could be a thermostat, but it was the same in my car.
08.05.2020 19:35 # 13
ssakyel
The same problem exists in me too. The temperature is between 70-74. I will be the master these days, I will share the results, friends.
08.05.2020 19:35 # 14
koray.turan
Handling another thing at 100% thermos is fixed with replacement t the koray.tur 2016-01-07 22:09:07
08.05.2020 19:35 # 15
ssakyel
Yes Koray, as you said, the thermostat side industry and it turned out to be defective.
08.05.2020 19:35 # 16
koray.turan
I am glad to get past you to solve the problem
08.05.2020 19:35 # 17
ssakyel
Thanks for your help.
08.05.2020 19:35 # 18
ssakyel
Friends that have not happened. Today I started having the same problem again.
08.05.2020 19:35 # 19
ssakyel
It goes up to 90 if I push it too hard. The thermostat had changed. It has not been more than ten days.
